doodling with MoI
All  1-14  15-19
534.15 In reply to 534.14
Hi Jesse, even though clines make it possible to place something in the right spot in one single command, sometimes it is not worth the planning effort that it requires to get it all set up just right. Like in this instance even though it is possible to draw a cylinder in the exact spot, it is kind of easier to draw it in the orientation and then move it off ot the side as a second step.
Also I don't think that there is anything wrong with your scaffolding method, that's probably more what I would do because it kind of gives you some pretty good visualization as you are setting it up.
But anyway, to do that the cline way here is what I would do - start the cylinder command.
Drag the first cline between the tips of your stones to set up a midpoint osnap:
Now drag the second cline between the origin and the midpoint of the previous cline:
I believe this gets you your correct orientation. So now zoom in there a bit (so you can more easily snap on to just the cline instead of on to the neighboring stones), and draw your cylinder:
Now for the second step you can drag it off to the side a bit, or use Transform/Copy with a distance constraint if you know the exact distance you want it displaced from the center line.
It would have been possible to relocate that oriented line off to the side a bit first so that your cylinder would be in the exact right spot right away, but I think that may actually be more complicated overall.
534.16 In reply to 534.13
Michael, MoI is not lite anything indeed it is in a class all by itself Kudos to you :) Thanks for the c line tutorials. I am getting better at learning to use them. Here are my recent doodle of this simple bottle/can opener in it I set out to really focus on using the c line among other things. Exercises like this make me focus on the minor details of this everyday object with fresh eyes and appreciate its use and design in new ways. Very much like MoI deceptive in its work flow and power even at this stage in its development. I hope that makes sense?
534.17 In reply to 534.16
Hi phlatt5th, that's a nice can-opener result. Nice clean construction!
534.18 In reply to 534.15
Thanks, It's good to know how to locate the c-lines so that you can control the orientation of the cylinder, I can use that for other things, as well... since the correct spacing and over-lap of the objects is crucial to having the model function in metal and real stones, and it's different for every finger size relative to the stone size, it takes some planning to lay these things out anyway, so maybe scaffolding in combination with some c-lines when you need them, would be a good solution.
-Jesse
534.19 In reply to 534.18
Yeah, I think so. There is some overhead to doing the scaffolding (invoking multiple drawing tools, erasing stuff later, etc...) but if you are already spending some time planning things then this overhead is not a problem.
But if you want something quick, for instance just getting a cylinder drawn at the correct orientation at an approximate height or lateral offset location for a type of quick visualization sketch, then clines keeps things moving along really speedily for that type of a thing because placing just one or two clines is super quick and there is no erase time. Like it might take you only 2 seconds to place the quick cline temporary "scaffolding" in place, but maybe something like 10 seconds to place regular geometry scaffolding, especially because for regular geometry scaffolding you have to trigger multiple commands and also possibly move stuff around a bit since you don't have the implicit extensions that clines have built in.
10 seconds versus 2 seconds is not a big deal if you've already spent a few minutes planning stuff out. But if you want to just draw and sketch stuff really quickly, it does become more significant because just a few more seconds starts to take away the rapid "drawing" type feeling...
Show messages: All  1-14  15-19
