Minor glitch
5331.1
Hi Michael ..
I have a big list of styles and now Alt+A does not seem to work for alphabetizing them. Is there a limit?
I have MoI open twice ... one on each of my monitors ... but the files are not the same.
cheers,
eric
5331.2 In reply to 5331.1
Hi eric, is it possible that the script for Alt+A is not set up anymore in your keyboard shortcuts?
Double check under Options > Shortcut keys, if it's not there then set it up from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3918.2
If that's not the issue then can you please send the file to me at moi@moi3d.com so I can test with it over here?
5331.3 In reply to 5331.1
Hi eric, thanks for sending me the file to test with - as I replied in e-mail, it turned out to be a bug in the sorting script where it would actually sort styles into 2 different sections depending on whether the style name started with an upper-case letter or a lower-case letter. It seems like there's always something tricky going on with programming... ;)
I've updated the original post with a new script (same one I sent to you through e-mail) so that it should not do that anymore and it should now work properly.
Thanks, - Michael
5331.4 In reply to 5331.3
Thanks Michael ...
Wow! What a remarkably fast answer. Works perfectly!
cheers
eric
