MoI to Keyshot with 3DM
All  1-3  4-14
I use KeyShot with MoI and the two programs play very well together. Output as OBJ and use Quads & Triangles as Michael recommends.
Just make sure you have assigned a unique color (Style) to each surface or solid where you want to assign a unique KeyShot material. The Style names you assign in MoI will come across into the KeyShot Scene Parts Tree, making it very easy to assign materials, show/hide parts, etc.
Ed
EDITED: 11 Aug 2012 by EDDYF
5325.5 In reply to 5325.3
Hi Martin,
> It does also beg the question as to whether you could do a plugin or another export option for MoI
> to output the render mesh, IF that's a possibility, then can i ask for it to be added to the wish list...
It's not a very easy fit for MoI to include an option for that because another difference between MoI and Rhino is that MoI differentiates between a "display mesh" which is one that's created for the realtime display and has an emphasis on being created very quickly, and an "export quality mesh", which is what you get when you save to a polygon mesh format.
The export mesher has more of an emphasis on quality and will do some much more time intensive calculations and also has a UI that pops up with it to allow you to control the meshing process.
If I were to just add an option to put display meshes into the 3DM file, the renderer that then used that would be receiving only the polygon data that was meant more for the realtime display. And if I instead tried to put an export mesh into the 3DM file that would involve popping up a mesh options dialog and additional mesh calculation for every save to 3DM format even though MoI itself would not use that data at all.
So either of those is pretty awkward. I don't see how it would work very well to add that in, it's not a great fit with how MoI functions. Really that particular 3DM data should be considered to be just a cache of Rhino's own display data and other programs shouldn't really be trying to use it directly as the main method of data transfer. It's basically relying on a side effect of something that Rhino itself only calculates and stores under certain circumstances.
5325.6 In reply to 5325.5
What you go and do that for, Michael - I am more confused now - lol, and it would not be fair of me to ask you to describe the difference between a NURBS render mesh and a polygonal render mesh, I will however offer my thanks for taking the time to tell me why it's awkward, and settle for the reality that is MoI can export what i need to get a job done, and that's all it needs to do to be honest, anything else is pure icing and cream, so keep dishing up those ingredients and i will stay loyal to the product. :¬)
Martin
5325.7 In reply to 5325.6
Hi Martin, well it's more like one is a "realtime display mesh" meant to be used for making a shaded display while modeling inside of a 3D viewport. It's overall tuned just for that purpose and takes some shortcuts with the mesh construction.
If you want to do something more "permanent" with the mesh like use it to produce a rendering or 3D print or something like that, then that's what the export mesher is for, it produces a mesh in a more careful way to make it have a higher quality structure.
The higher quality export mesh takes longer to calculate than the "realtime display mesh" - that's one of the reasons why there are 2 different mechanisms, because when you are just doing modeling you probably don't want to wait around extra time every single time you do any kind of model edit. So it helps make modeling have less hiccups just in your general workflow for the meshing there to be prioritized on speed.
So it's not that one is a "NURBS mesh" - it's that one mesher produces results more quickly but messier, and the other produces polygons more slowly yet higher quality.
If the mesh is going to be used for some kind of more involved operation like producing a final quality rendering, then that's when the "slower but higher quality" mesher makes more sense to be used.
If the mesh is going to be used only for the display of stuff on the screen while modeling only, then that's when the "faster but messier" mesher works better.
5325.8 In reply to 5325.7
i also use moi & keyshot on a mac, export to .stp and import
into keyshot with the old importer. tessellation will be done by keyshot
and you get smooth surfaces, plus all your defined parts....
5325.9 In reply to 5325.8
Just tried that here but it failed to import, Keyshot says no geometry, strange the file is almost 80mb - lol .... Obj stays the flavour that suits, for now.
Thanks for the info though schneich
Martin
5325.10 In reply to 5325.9
it works! you must klick on "advanced" and select "old importer"...
also i use keyshot version 2.2
cheers
t.
5325.11 In reply to 5325.10
This is version 3.099 and i did click advanced and old importer was selected but it still said no thanks. It's not a biggie, OBJ will do
Martin
Edited 16.08.2012 - Iges import does work in version 3 too. However, you should not use the old importer and when exporting to iges file, you will need to hide or delete any curves or Keyshot will bomb out with a "no 3D geometry found" error.
Hope this helps anybody else with the same problem ....
Martin
EDITED: 15 Aug 2012 by TPWUK
5325.12 In reply to 5325.11
good to know...
thanks
t.
5325.13
Hi Martin,
The current KS Version is: 3.3.15
5325.14 In reply to 5325.13
Hi Ralf, thanks for the message, yes 3.3.15 is the latest release but it has nothing added to it to be of any value to me to install it. If it aint broke don't fix it applies to me. Plus it's not my copy (yet), and I need more time than Luxion allow to test things because i actually spend the vast majority of my day having to take care of my disabled wife. Sadly most companies don't take these circumstances into account, and that does sadly include MoI, but a 200 quid gamble with MoI and it's excellent support from its users and from Michael is far safer than a 2000 pound gamble with Luxion when they cant even answer a question about how come they can interpret IGES NURBS, but not MoI/Rhino ones. So for now Keyshot is experimental to me at this time and is likely to stay that way until i can afford the gamble or until my friend wants his back.
Martin
Show messages: All  1-3  4-14
