jscript Klasse unterstützt keine Automatisierung
532.1
hallo!
wenn ich aus einem spline einen körper erzeugen will kommt die Fehlermeldung "jscript Klasse unterstützt keine Automatisierung"
Wie kann ich das beheben?
532.2 In reply to 532.1
Hello! Sorry I can't write back in German, hopefully you will be able to understand this.
This error means that some of the scripting mechanisms in Windows have become messed up on your machine. It is possible to restore these by doing these steps:
Open a command prompt by going to Start / Run and type in "cmd.exe".
At the command prompt window, type in these commands:
regsvr32 msscript.ocx [enter]
regsvr32 dispex.dll [enter]
regsvr32 vbscript.dll [enter]
regsvr32 jscript.dll [enter]
That should write fresh entries for all the scripting stuff into your Window registry. Somehow your registry has gotten messed up.
Please let me know if that doesn't fix the problem.
532.3 In reply to 532.2
hallo!
I have just done it!
if I want to provide spline comes a Window with " Script errors Line 42 column 3"
it buttons disappear to provide splines :(
help please!
532.4 In reply to 532.3
Hmmm, one additional thing you can try is to use the IE7 reset. There have been some cases where this also helped repair someone's settings.
This is described in this blog: http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx
From IE7, go to the Tools Menu, Internet Options, Advanced Tab, and click on the Reset button near the bottom.
That may also help restore your registry settings.
532.5 In reply to 532.4
I do not use explorer any more since version 7 not more because he no more functions.
resetting has not helped.
532.6 In reply to 532.5
MoI uses some pieces of IE, that's why a reset might have helped even if you don't normally use IE7 as your web browser.
But if that didn't help I'm afraid I'm out of ideas, sorry....
MoI relies on some scripting engines and parts of IE to be working properly on your machine - if they aren't working right then MoI can't function properly.
532.7 In reply to 532.1
@bestrafer
Wenn du ICQ hast und das Problem noch immer bestehen sollte, melde dich mal bei mir 46210408.
Tritt der Fehler nur bei der einen Aktion auf oder auch beim Ausführen anderer Befehle?
Welche Windowsversion und welche Browser hast du auf deinem System (IE6, ... ?) installiert?
MfG
sk2k
532.8 In reply to 532.7
i have deinstalled the fucking iexplorer 7!
alles ok!
