MoI3d 1.1 Glitch/Broke!
All  1-4  5-20
5318.5 In reply to 5318.4
Dose it matter that i have IE9?
5318.6 In reply to 5318.5
Hi Arymond,
No, that should be ok, there is a cosmetic glitch with IE9 where it can cause Moi to initially come up with a white screen and then it operates normally after that, but that does not seem to be what you are running into.
Either you've got some kind of IE add-ons that are not working right or something in your system registry has gotten mangled and that's preventing IE from functioning normally. If you use that reset button it will purge your registry (only the parts related to IE functions) and reset it all back to "factory defaults" so that may solve it if registry corruption was the particular problem that you were hitting.
5318.7 In reply to 5318.6
i do get the white glitch too :P but yes i think this might have happened after uninstalling some nasty tool-bars from IE and Cleaning up the Registry afterward and completely uninstalled IE and re-installed it and restarted my computer now I'm able open 3dm files and everything else is still broken ):
5318.8 In reply to 5318.7
Hi Arymond, the white glitch will probably go away if you maximize the MoI window and leave it maximized when you close it down so that it will start up maximized initially when launched.
Have you tried the IE Reset button that I've mentioned previously yet? You're probably running into some mangled registry settings from whatever registry cleanup that you did. Doing the IE reset may help solve that.
5318.9 In reply to 5318.8
yes i did hit the Reset IE button in Internet Options > Advanced Tab
5318.10 In reply to 5318.9
Do you get any different behavior leaving IE9 uninstalled and using IE8 instead? Maybe try a reset with IE8 as well.
If that does not help then it looks like somehow you've got your IE mangled to such an extent that you may need to wipe your system and do a fresh re-install of Windows to get MoI working again there. Either that, or update to use the MoI v3 beta release instead of version 1.1 - the v3 beta release does not use anything from Internet Explorer anymore and so it's immune to this kind of mangled IE type situation.
5318.11 In reply to 5318.10
i wish i could afford v3 then (or v2 to get the pre-beta)
allso i only have IE9 not 8
5318.12 In reply to 5318.11
Hi Arymond,
Initially Windows 7 comes with IE8, if you've got IE9 that's been installed as an update and so you can probably uninstall the update and go back to IE8 and see if that behaves better.
I think you can find the uninstall for IE9 in Control Panel > Programs > "Programs and Features" > View Installed Updates > Microsoft Windows section > "Windows Internet Explorer 9". Right click on that and pick "Uninstall", hopefully that will bring you back to a maybe-functioning IE8 install.
5318.13 In reply to 5318.12
Thank you SOO Mucchh!
My Inspiration is truly back, silly IE9 Broke everything!
Now I'm back to IE8 and everything is how it once was before my issues!
5318.14 In reply to 5318.13
Hi Arymond, that's great, I'm glad that you are back up and running now!
5318.15 In reply to 5318.14
ok now im getting a Script error "line 121 column 3"
when i try to use Scale commands same with rotate but line 122
5318.16 In reply to 5318.15
Hi Arymond, unfortunately it means that your IE is still probably broken somehow. Did you also try the reset button with IE8 , or did you only try the Reset when you had IE9 installed?
Also do you have any anti-virus or anti-spyware type systems installed, especially ones that try to hook into Internet Explorer and prevent it from doing some kinds of things? If so then it's possible that those are interfering with MoI's operation so try disabling any invasive programs like that which you might have running.
5318.17 In reply to 5318.16
All i have is MSSE and Advanced System Care 5
i Don't see the same Reset button for 8
5318.18 In reply to 5318.17
Hi Arymond, the reset button was introduced in IE7 so it should be there in IE8.
Open up Internet Explorer and go to Tools -> Internet Settings -> Advanced tab and it should be there on the bottom of the dialog.
I'm not familiar with Advanced System Care - when I do a Google search for:
"Advanced System Care" Internet Explorer
Some various stuff comes up with complaints about it messing up Internet Explorer. So that could definitely be related.
You may need to get rid of the "Advanced System Care" program if it messes up how other programs interact with the Internet Explorer engine.
For example the very first comment here mentions that using it broke a different app that is also trying to use IE as well:
http://download.cnet.com/Advanced-SystemCare-Free/3640-2086_4-10991574-2.html
5318.19 In reply to 5318.18
i removed it from my computer but i'm still getting the error even after resetting IE8 again it happens with any of the construct and transform tools
5318.20 In reply to 5318.19
Hi Arymond, sorry I don't really have any other suggestions for you at this point other than to either switch to MoI v3 or to back up your important data and wipe/reformat your drive and do a fresh install of Windows.
It seems that you're Internet Explorer installation has gotten really messed up, and from some of those comments that I read it looks like that particular anti-virus/anti-spyware system could be what got things messed up in the first place.
You might check out if you have any system restore checkpoints from some time when your system was working properly and try to do a system restore back to then.
Maybe it could be worth a try to install IE9 now without that other system running and see if you end up with an ok installation after that.
Show messages: All  1-4  5-20
