Short cut key for snapping
5317.1
Hi, is there a script that would allow me to assign a key to each of the main snapping options in MoI - Grid, Straight and Object. It would help my work flow if I could do this.
M
5317.2 In reply to 5317.1
Hi Mark!
Toogle GridSnap:
script:moi.drawingAids.gridSnap = !moi.drawingAids.gridSnap;
Toogle StraightSnap:
script:moi.drawingAids.straightSnap = !moi.drawingAids.straightSnap;
Toogle ObjectSnap:
script:moi.drawingAids.objectSnap = !moi.drawingAids.objectSnap;
I'm using them with F5, F6 and F7.
~ Marco
EDITED: 9 Aug 2012 by MARCO
5317.3 In reply to 5317.2
Brilliant! Thanks for that. Is there a script to set up a short cut key for the Reset button that appears when you mouse over it in the display?
M
5317.4 In reply to 5317.3
Hi Mark, to do reset on a shortcut key put the following script in for the command part:
script:moi.view.resetAll();
5317.5 In reply to 5317.4
Thanks Michael - :-)
5317.6 In reply to 5317.5
Up until a couple of months ago I was using MoI for converting IGES file from Inventor into the .lwo format for use in Modo. It worked really well but now that I am getting the hang of MoI I only use Modo for texturing and rendering. I do all my modelling in MoI now. It's much better suited to me and what I do. Brilliant!
M
5317.7 In reply to 5317.6
Hi Mark, that's awesome that you're using MoI for more modeling tasks now too!
You're probably getting the hang now to see which kinds of projects suit MoI's workflow well - for more structured mechanical type things MoI's workflow of constructing lots of things from 2D curves and make those kinds of projects come together really quickly and also accurately. For things that are more organic like characters and faces and things like that, those are less able to be driven by 2D curves and Sub-d modeling in Modo is a better fit for those kinds of projects.
