edges won't fillet
All  1-7  8-10
5311.8
Thanks Michael,
Some good explanations here.
The model started out in Rhino. The template I used was small objects meters: Units: Meters Absolute tolerance: .001 m.
What would be the best unit and tolerance setting in Rhino for bringing stuff into MoI?
Bill
5311.9 In reply to 5311.8
Hi Bill,
It depends on the size of the object that you're building - but if your object is going to be less than 1 meter in size it's probably best to use centimeter units for it instead of meters.
5311.10 In reply to 5311.9
Most of the stuff I build is the size of a building, but usually there are a lot of associated small elements like the one that started this thread.
Thanks for your help.
Bill
Show messages: All  1-7  8-10
