Plotting lot lines
All  1-3  4-10
5307.4 In reply to 5307.1
Hi yakas, the compass measurements will need to be converted to regular angle measurements, it looks like Brian has included information above on how to do that, please let me know if you are still stuck on that part.
Once you have converted those, you can then use polar coordinate notation to enter in the coordinates:
http://moi3d.com/2.0/docs/moi_command_reference1.htm#__XYZ%20/%20Distance%20/%20Angle
Polar coordinates are entered using the < symbol in the form of:   dist<angle
So for example to make a line that has a length of 5 and an angle of 32 degrees, you first place the start point of the line and then for the second point enter in polar coordinates by typing this:    5<32   and push enter. That will tell MoI to place the current point at a distance of 5 units and an angle of 32 degrees away from the previous entered point.
Got in some practice with the polar entries.
It seems that some data is missing.
Here is a picture of the excel decimalization of the angles.
Here is a picture of the property lines. There is not closure.
The gap is about 1.8 feet.
Here is a picture of the two curves.
The radius for the two red curves is huge.
There is no way to locate where the curves would be located on the property.
They are almost straight lines...
An unwrap of the two red curves shows lengths of 72.6391feet and 70.8194789 feet, pretty close.
You would have to locate the two curves on the property.
5307.6 In reply to 5307.5
Wow, thanks for all the effort you guys. I attached the full image so you can see how the lot (Parcel 2 - .66 acres) looks, maybe it will offer a clue as to the missing lines. I also attached a drawing I did of the park design traced from my Moi model(just for fun). Thanks
5307.7 In reply to 5307.6
Cool project.
Oops, C1 and C2 are the (not) "missing" pieces. I thought they were part of the track.
Here is a .3dm which should be very close. Made the red curves tangent at one end each.
Not exactly sure how the surveyors do it.
EDITED: 19 Feb 2014 by BEMFARMER
5307.8 In reply to 5307.7
Thats perfect, thank you. I'll put a picture of you up on our supporter collage if your interested. It will be visible on our upcoming revamped website. check it out in one our our posts: http://www.facebook.com/Carpinteria.Skate.Foundation
5307.9 In reply to 5307.8
Hi yakas,
Cool skatepark concept, if you like you can download some skatepark elements from http://grabcad.com/challenges/skateable-art-or-obstacle-for-american-ramp-company/entries they are free to use or you can contact the designer to ask permission to use commercially, I'm sure they'd be happy to get a mention on your design.
5307.10 In reply to 5307.9
there are some cool designs on there, thanks
Show messages: All  1-3  4-10
