2d blend and trim
All  1-2  3-7
5304.3 In reply to 5304.2
Ok, thanks Michael!
Concerning quicktrim, I wonder how it could behave with closed curves...
Maybe it could just make an open path out of a closed one when clicking, the starting point being where the user clicked.
Marc
5304.4 In reply to 5304.3
I was doing some leaves this morning (with flow deform it's amazing!) and it got me thinking again about some kind eraser function.
It would definitely speed things up when doing some 2d blending with curves.
The minimum radius could be rather large so there would not be a lot of tiny pieces left.
Unselected objects would not be affected by the function.
It could also work with the wacom eraser.
It might seem out of place in a cad program but could be surprisingly productive when exploring shapes.
Marc
"... something that was a kind of quick trim of everything past the end of the curve"
I agree. I think a single click to auto-trim over hanging segments from intersected lines (and join the result) would allow for very fast drawing.
Much like quick hand sketching where you are concentrating on the overall shape (and not clean end points) and go back and erase the over-hanging lines.
I know you can use the current Trim function, but not in a single click as far as I know.
Would be a neat feature especially when used with fillet to round the intersections afterward.
Good for tablet drawing as well.
Ed
5304.6 In reply to 5304.4
Hi Marc, re: Eraser function, are you talking there about something that's just totally driven by mouse movements alone (like cutting things by a roving circle around the mouse basically), or do you mean something that would use other current geometry in the model as the cutters?
5304.7 In reply to 5304.6
It could work in two modes:
1 : Like some kind of quicktrim where everything under the drag would be cut to the nearest crossing curve.
2 : Like a big lazy eraser using no existing geometry, wiggle and trim in one click.
Both could use a round adjustable radius, like a kind of paintbrush.
An example of the fist behavior, one could swipe through (in red):
And get this result
There could also be an alternate selection mode using this method, sort of paint to select.
It would be quite quick for complex multiple line or point selection...
Just thoughts.
Marc
Show messages: All  1-2  3-7
