Hi Brian, that sounds promising! Agustin that is probably your best bet since it will be quite difficult to find support for Euclid files.
> Not sure where the input and output files go, maybe in the .bin folder? ...
Probably they can go anywhere if you give the full path in the filename (try putting " " around the filename if there are any space characters in it). But if you don't have a full path and just put in the filename by itself usually a command line program will use the current directory. So yeah putting the input file to translate in the same .bin folder may be easiest.
