extension XDB
All  1-2  3-7
5278.3 In reply to 5278.2
Hello Michael
Thanks for your quick answer
I have download BRL-CAD to try , but it's very hard to do something.
Indeed euclid software is an old software .
I have find a french factory witch , perhaps can help me .
Take a look on the next link :
http://www.defi-groupe.com/2/accueil_fr.php?menug=4&menuh=m8
i will phone them tomorrow if my boss agrees
excuse me for my bad english and thanks again
chri
5278.4 In reply to 5278.3
Hello Christian,
I´m facing the same problem, have to convert some old Euclid files to STP or IGS format but can´t find a converter, could you tell me how you solved it?
Thanks in advance for your help,
Regards,
Agustin
I downloaded Brl-Cad, but it is not a very friendly program. There is some (obtuse) pdf documentation.
It seems to consist of 3 programs.
MGED is the geometry editor.
RtWizard is for ray trace.
Archer is for ?
One of the several pdf manuals gives command line instructions to convert from a Euclid database: euclid-g i (Euclid_db filename) o (brlcad_db filename).
The option "i" is for input file. The option "o" is for output file
Finally found the program euclid-g.exe, in the BrlCad .bin folder. It produces a command line box for typing in instructions.
Not sure where the input and output files go, maybe in the .bin folder? ...
5278.6 In reply to 5278.5
Hi Brian, that sounds promising! Agustin that is probably your best bet since it will be quite difficult to find support for Euclid files.
Probably they can go anywhere if you give the full path in the filename (try putting " " around the filename if there are any space characters in it). But if you don't have a full path and just put in the filename by itself usually a command line program will use the current directory. So yeah putting the input file to translate in the same .bin folder may be easiest.
5278.7
Hi! Thanks a million all for your fast reply, I will download Brl-Cad and try to convert the euclid files... Gonna write you later with results, hope it works!!
Regards,
Agustin
Show messages: All  1-2  3-7
