Line (tan,tan)
 1-13  14-21
5253.14 In reply to 5253.13
@Burr
No, i believe that is just for the method ;)
Felix wants not add more circles than existing for draw the tangents !
And wants even a special function : just click 2 circles and the tangents will drawn! (internal(s), external(s), both)
But don't know if Michael will make that ;)
EDITED: 13 Jul 2012 by PILOU
5253.15 In reply to 5253.14
""""""""""Felix wants not add more circles than existing for draw the tangents !"""""
Yeah, but the Tan/Tan snap does this.
"""""""""""just click 2 circles and the tangents will drawn! (internal(s), external(s), both)""""""""
Oh, ok. A script that automates it is the request.
5253.16 In reply to 5253.15
Not this?
5253.17 In reply to 5253.4
Hi Felix, maybe I'm a little bit lost with what you're discussing here, but like Burr says above, MoI does have a tan/tan snap that you can use to construct these kinds of lines without needing to do any of that additional extra work.
> here is a simple 2d drawing where I was trying to create the blue lines. For what I would call the "external"
> tangent lines, the solution is to create a circle inside the larger circle with a radius of R2-R1 then draw a
> line from the center of the small circle tangent to this circle we just created and translate this line to the
> edge of small circle (followind the perdendicular radius).
You don't need to do any of this additional circle construction and line translation - just draw in a single line and it will give you a tan/tan snap point that you can grab on to. It's a special snap that not only snaps the endpoint of the line but also moves the base point of the line as well. It also works on bendy curves as well, not just circles.
In order to use it make sure "Object Snap" is enabled in the bottom toolbar, and also make sure you have not disabled "tan/tan" snap type in the object snaps list, and then you just draw in a line nearby where the tan/tan line is and move your mouse until you find the snap point that is created, it is usually just a short distance away from the single end-point tangent line.
See here for a previous example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2788.4
EDIT: and I was going to do a video showing it on your same file too but it looks like Burr has done that already, thanks Burr!
So none of that extra work for constructing circles and moving lines is needed, just draw a single line in fairly close to where the tan/tan line is at and there will be a snap point created that you can move your mouse to which will then give you the tan/tan line, it works on curves as well.
5253.18 In reply to 5253.1
There's also a similar perp/perp snap that you can use to create a common perpendicular line between things in a similar way as the tan/tan snap:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3042.13
5253.19 In reply to 5253.1
Hi Felix, so notice in Burr's video above how he just uses the line drawing tool and that's all that is needed for putting in tan/tan lines - he just places the line in nearby where the tan/tan line is, then there will be a snap point created on the second circle (or curve, it works on any bendy curve as well) right at the tan/tan location and if you put your mouse on it the tan/tan snap will engage which will also move the base point of the line. You can tell when that special tan/tan snap engages because a "Tan/Tan" tag will appear on not only the end point of the line but also the start point of the line as well - with that snap the start point of the line is also adjusted. Here's a previous video of this in action:
Move your mouse a little ways along the second curve until you find the tan/tan point and then you'll have these lines you need without doing any special extra construction work.
EDITED: 13 Jul 2012 by MICHAEL GIBSON
Aaaaaaaaaaaaaaaahhhhhhhh :)
That is some magic! Never seen these 2 posts or did'nt remember this double move back !
Script was yet existing :)
So i had learnt the mehod for pencil and paper ! :)
5253.21 In reply to 5253.16
BurrMan,
that's exactly it. No need to construct any thing extra.
Thanks to all as well,
Felix
Show messages:  1-13  14-21
