new beta soon?
 1-9  …  50-69  70-89  90-109  110-119
5252.90 In reply to 5252.87
Hey PaQ,
Do you have another display script with the more detailed output from something previous?
"frames" + time
Thanks.
5252.91 In reply to 5252.88
Hi PaQ,
> So for the next test I keep nvidia thread optimisation on 'auto', but I
> disable the intel hypertreading on my mobo.
So it looks there that hyperthreading being turned on in the bios by itself doesn't harm anything but that there's not much to gain there by one thread per "virtual core", and that the increased contention ends up as a slight net negative.
This probably has to do with the whole process being memory bandwidth intensive instead of only calculation intensive which would suit hyperthreading somewhat better I think.
I think it will probably be best to go with a default of one thread per "real core" instead of one per "virtual core" for this particular thing.
5252.92 In reply to 5252.90
You're welcome, glad if it helps.
Hi Burr,
Not sure if I understand what you're asking.
I'm using fraps to benchmark the viewport (http://www.fraps.com/ ), with the autorotate2 script here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1001.1 .
5252.93
Using time display script in MoI....
1000 Spheres in Array (cube arrangement), mesh=5 deg.
2000 ms in prior version.
1069 ms in new version.
2x increase.
So it's good for larger shear quantity of surfaces. - when its more about large amounts of poly data being processed.
Not as much noticeable with simpler models. - when it's more an issue of the bottleneck with the PC communicating with the vid card.
In one case, when I was using a smaller number of objects. I noticed that the newer version was slower than the older.
5252.94 In reply to 5252.93
Hi Mike,
By very much or were they pretty close? But also with a small number of objects things are probably going at a fast enough pace that you probably would not be able to tell the difference if the numeric readout was not there, or was that not the case?
5252.95 In reply to 5252.92
Hey PaQ,
"""""""""Not sure if I understand what you're asking. I'm using fraps to benchmark the viewport """"""""""""""""""""
Ok, my bad... I thought you were doing it with the script Michael posted. we only got "ms" with the script. I didnt know how you were getting "frames per second."
Thanks.
5252.96 In reply to 5252.38
Very cool... Thanks Michael... I'll announce this new beta an my forum as well.
Peace,
Rich_Art. ;-)
5252.97
Great job Michael G. on the tapered extrude! Good for folks like me that do injection molded plastic part designs!
Michael T.
5252.98
Is this new cpu optimization working on the mac version??
5252.99 In reply to 5252.98
Hi ed,
Yup, the same thing is working on the Mac too. I only have dual-core macs over here, and I saw about a 30% improvement, a quad-core should probably see better than that.
5252.100
Michael, I'm seeing a possible bug with the new version:
FreeForm curves (control point, Through Points, and Sketch) are not allowing you to highlight them or select them in one ortho view if you created them in another one.
Regardless of how they were drawn in one view, it seems to happen when they appear "planar" in another view.
It appears to be intermittent and is random in occurrence. (So if you try, try a few different times)
Scrolling in and out seems to bring this problem on and off.
I've drawn some FreeForm curves while in "Front" view, I go to "Top" view and Moi is not highlighting them for selection.
Nor am I able to move them.
This is also happening in the same view I draw it in. But it will sometimes work again, then not work if I zoom.
It doesn't seem to be a problem with non-planar curve objects.
Also strange, I don't seem to be able to snap things to it's ends or other parts... almost like it is invisible when seen in planar.
Even if I select it with a window selection, I still can't move them.
Oh, and some (objects planar in view) are highlightable/selectable and some will not.
And those invisible objects do not have the preview-to-snap "x"'s within the tolerance circle, not show up either.
The same effect is happening with shapes, lines and anything else planar, like a Planar box. I've rebooted just to clear up that possibility.
I also set the thread limit to 1, just to rule that out.
Just for comparison I've opened up the older version and pasted the same things into it...
Of course, No problem in the older one. The older version seems to have less lag when moving things, and everything highlights with a mouseover just fine.
Anyone else have this issue? Draw a FreeForm curve with a few points in one flat view, (in a straight fashion (no curving)) and go to another flat view and see if it is not selecting.
I just noted that this doesn't seem to be a problem between views in Split View, it's just the full version single views of each viewport.
Also, there seems to be a little lag time when I try to move control points over the previous version.
Also a lag when I am using box selection. The box is somewhat behind in catching up to the cursor.
EDITED: 22 Jul 2012 by MAJIKMIKE
5252.101 In reply to 5252.100
Curious all that works fine for me!
Have you a little video of this ?
5252.102
Of course not. ;-)
If no one else is able to reproduce this, I'll try at work tomorrow and thus determine that my home PC truly sucks.
5252.103 In reply to 5252.102
Look at MoI-options-snaps and read the numbers there.
5252.104 In reply to 5252.100
Hi Mike, I can't seem to repeat anything like what you are describing over here.
Can you repeat this problem when loading in a saved 3DM file instead of only just drawing a new curve? If so then if you could post a 3DM file where you do see it, that would be an easier thing for me to test with over here rather than just drawing random curves because maybe you have some tendency to draw a particular shape of curve that is more likely to trigger the problem or something like that.
Do you have other objects in the model like solids that the curves may be behind?
You say it only happens to you with a full screen view and not in split view? What method are you using to switch between views, any kind of script or just the view tab buttons on the bottom command bar?
Do these also persist if you set DisplayThreadLimit=1 ?
5252.105 In reply to 5252.100
Hi Mike, my guess is probably what happened with the new version is that you have adjusted some driver settings for it and turned anti-aliasing on. When anti-aliasing is forced on at the driver level it will entirely mess up MoI's selection mechanism.
You probably have some app-specific settings for each different MoI.exe, or an app-specific setting that is only getting applied to the new one and not the old one.
Try going in and removing all special video driver settings for the new MoI.exe, especially anything related to forcing anti-aliasing on and then likely your problem will go away at that point.
5252.106
Wonderful... :-/
I checked my vid settings and there are not specific applications set up to run special 3d setting cases.
My Snap settings are set to factory default.
I do know that this is NOT happening in a parallel opened version of Apr beta. (or so I thought - it is more based on the physical arrangement in the display... see below the pics).
http://www.k4icy.50webs.com/tutorials/selection_test_01.3dm
Here is my test file, but from the sounds of it, anything out of the ordinary is only happening to me... "I saw it, it took a bite out of my boat" he says. ;-)
This strange selectivity changes with the scale at which I zoom in and out.
I took further measures to rule in/out the anti-aliasing setting in the Invidia setup.
(NVIDIA GeForce4 Ti 4800 SE)
With anti-aliasing turned completely off, selection works fine!
--you have to re-load MoI after changing--
With it set to something called 2xQ, I am NOT ABLE TO SELECT ANYTHING!
Something called "4x" is its highest setting, this is where I was currently set at.
I am able to achieve this 'selectivity' with the older version too.
By the way, it all seems to work fine when the anti-aliasing option for the Invidia card is set to "Application Controlled".
Which means that there is no card-forced anti-aliasing to the operation of MoI.
(the above pics are kinds moot now)
Thanks for the quick advice Michael... Knock on wood, I think this may be it.
I changed these settings to "default 'Quality' " when I was messing with it the other night. It changed it to "4x" anti-aliasing from "Application Controlled"
Since I can control this effect that I was experiencing by changing these setting, we must assume that this was the issue.
The other two issues with the lagging seems to have cleared up too.
:-) Whew! (for now)
5252.107 In reply to 5252.106
Hi Mike that's great, so from what I understand you're all set now with the driver anti-aliasing setting put on "application controlled" which probably was originally the default, before you must have done a few tweaks to see if things like "threaded optimization" would help with performance, is that correct?
So it sounds like you are all back in working order now?
And yes, if antialiasing is forced on at the driver level it will definitely mess up MoI's selection mechanism, it basically ends up anti-aliasing and therefore mutating some selection data. With it back to the default "application controlled" you should be back in action now.
Also having antialiasing turned on makes the card do quite a bit of extra work so with an older card that's also not unusual that it would have some performance penalty along with that as well.
5252.108
Great! it works on the mac too!!
5252.109 In reply to 5252.108
Hi Ed, do you see a noticeable improvement on your Mac?
You can get some actual numbers by setting up the following on a shortcut key, then pressing that will show the redraw time in the upper-left corner of the viewport window:
script: /* Toggle redraw time display */ moi.ui.showViewportDisplayTime = !moi.ui.showViewportDisplayTime;
Then with an actual number on the old one and a new number it's easier to tell exactly how much improvement there has been.
Also, what kind of CPU and video card do you have on your Mac?
Show messages:  1-9  …  30-49  50-69  70-89  90-109  110-119
