new beta soon?
 1-14  …  35-54  55-74  75-94  95-114  115-119
5252.75 In reply to 5252.73
Hi beanworks,
> got a dumb question. Where might I find my license key?
Well, it's sent to you by e-mail originally. Right now it is not displayed in the actual program UI anywhere but it is written as a text file which you can open up in a text editor (like notepad on Windows or TextEdit.app on Mac) to see.
The text file is in the same location as moi.ini, and will be named moi_v2_license.key - you can find out where your moi.ini file is at by going to Options > General , and push the "Edit .ini file" button. In the dialog that pops up, it will tell you where the ini file is located at and your moi_v2_license.key file should be in that same directory.
5252.76 In reply to 5252.72
Hi danperk, that is a great speedup, and cool twisty model too!
What video card are you using on that machine?
5252.77 In reply to 5252.76
Thanks! I'm running an ATI 5870 - 1GB & Intel 930 Quad.
5252.78 In reply to 5252.75
awesome, found it. thank you for everything!
5252.79
Okay!
I tried a model on my home PC.
I have a Pentium 4 (2 core), 1 g. ram
NVIDIA GeForce4 Ti 4800 SE
I see one core taking the brunt in the older version, and two cores working just as hard in the new one.
MoI's timing with this particular model:
116 ms and 100 ms. %14 (?)
5252.80 In reply to 5252.69
""""""""""""But also now that I see what your test file is like, a "sphere grid" is actually a particular kind of case since each sphere only has a single edge in it. So your test file happens to be heavy on surface drawing and light on edge drawing, and it's actually edge drawing that consumes the most CPU and also therefore has the most to benefit from the multi-core use as well.""""""""""
Rat's... We already talked about that... Shouldve known.... Never mind.
5252.81 In reply to 5252.80
Re-tested on an edgy model.
V2 = 220 ms
V3 = 120 ms
Much better. my bad.
5252.82 In reply to 5252.81
Hi Burr, yup that's more like it... Also an edgy model with Hidden line display enabled will probably see the biggest difference.
With this edgy model, do you see any difference if setting DisplayThreadLimit=6 or DisplayThreadLimit=8 on your dual-quad-core ? I'm still not so sure that one thread per "virtual" core is the best way to go on a hyperthreaded machine or not.
5252.83 In reply to 5252.79
Hi Mike,
Not really too surprising there isn't much gain there, because the GeForce4 Ti 4800 SE is basically an antique at this point - it comes from the 4th generation nVidia wave, they are on the 15th generation right now...
Especially if it's in an AGP 1x or 2x slot probably the card is the bottleneck. Multi-core CPU use can only help things out if the video card and bus is speedy enough that the card can handle more stuff than what one CPU can chug out. If the card is not able to keep much ahead of just 1 CPU then having more than 1 CPU also going won't really do much.
However recent trends have been that video cards have become faster at a greater pace than CPUs - for various reasons CPUs are basically stuck at around their current speed and the focus is more on having several cores available, so this new system in MoI is pretty good for the direction that things are going.
Your GeForce4 card though is nearly 10 years old at this point, as far as GPUs go that's like an eternity, it's basically a nice feature that MoI is able to run at all on these kinds of old generation cards (MoI actually does run on the 1st generation GeForce and Radeons!), but you're probably not going to get much benefit for things that are tuned more for current generation stuff.
I would have expected a better result on your work machine though definitely... From what you were describing it kind of sounds like the multi-core use of the driver is still on despite changing that setting, I don't know if possibly that is a driver problem that has been fixed in a newer driver version, but that could be possible.
5252.84 In reply to 5252.82
"""""""this edgy model, do you see any difference if setting DisplayThreadLimit=6 or DisplayThreadLimit=8 on your dual-quad-core ? I'm still not so sure that one thread per "virtual" core is the best way to go on a hyperthreaded machine or not.""""""""""
Video card defaults
no entry in MoI ini thread limit = 130
thread limit 6 = 140
thread limit 4 =150
thread limit 1 =180
Video card threaded optimazation off in global, no entry in ini file = 150
Seems about right.
5252.85 In reply to 5252.84
Hi Burr, thanks for those tests!
So it does not seem that one separate thread per virtual core (which is what you should be getting with no entry set, or with it set to 0) is hurting anything there, that is good to know.
5252.86 In reply to 5252.83
What I need is $2k after taxes. ;-)
The card was a quick replacement after lightning took all kinds of stuff out in my home PC, including the better card.
The motherboard is the only thing left that wasn't (too) effected, and it has evident charring around the power strip connector.
I'm still going to poke around some next week to see what the deal is with my work PC...
My brother put it together a year ago, and he tweaks gaming systems as a hobby.
I believe for the sake of keeping my boss from having anymore headaches, he clocked everything down to "reliable" and "stable" values.
And I remember a lot of stuff done in the fancy BIOS setup.
Ya gotta admit, you can still do a lot with MoI on an old system... the watch, the tank. ;-) Now that's a product.
5252.87 In reply to 5252.85
260GT - i3930K
April
Frames: 76 - Time: 10000ms - Avg: 7.600 - Min: 7 - Max: 8
July
Frames: 116 - Time: 10000ms - Avg: 11.600 - Min: 8 - Max: 13 No DisplayThreadLimit - Nvidia Thread opt: Auto Hyper Thread ON
Frames: 119 - Time: 10000ms - Avg: 11.900 - Min: 11 - Max: 13 No DisplayThreadLimit - Nvidia Thread opt: Off Hyper Thread ON
Frames: 97 - Time: 10000ms - Avg: 9.700 - Min: 7 - Max: 11 No DisplayThreadLimit - Nvidia Thread opt: On Hyper Thread ON
Frames: 104 - Time: 10000ms - Avg: 10.400 - Min: 9 - Max: 12 DisplayThreadLimit=2 - Nvidia Thread opt: Auto Hyper Thread ON
Frames: 105 - Time: 10000ms - Avg: 10.500 - Min: 9 - Max: 12 DisplayThreadLimit=2 - Nvidia Thread opt: off Hyper Thread ON
Frames: 104 - Time: 10000ms - Avg: 10.400 - Min: 9 - Max: 11 DisplayThreadLimit=2 - Nvidia Thread opt: on Hyper Thread ON
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=4 - Nvidia Thread opt: Auto Hyper Thread ON
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=4 - Nvidia Thread opt: off Hyper Thread ON
Frames: 119 - Time: 10000ms - Avg: 11.900 - Min: 10 - Max: 13 DisplayThreadLimit=4 - Nvidia Thread opt: on Hyper Thread ON
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=6 - Nvidia Thread opt: Auto Hyper Thread ON
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=6 - Nvidia Thread opt: off Hyper Thread ON
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=6 - Nvidia Thread opt: on Hyper Thread ON
Will do an other batch with Hyper Treading OFF ... (does the result make any sence for you Michael Oo)
EDITED: 3 Dec 2015 by PAQ
5252.88 In reply to 5252.87
So my conclusion, the nvidia thread optimisation 'auto' is in fact turned off for MoI.
Forcing in 'on' slow down the result.
So for the next test I keep nvidia thread optimisation on 'auto', but I disable the intel hypertreading on my mobo.
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 No DisplayThreadLimit - Nvidia Thread opt: Auto Hyper Thread OFF
Frames: 107 - Time: 10000ms - Avg: 10.700 - Min: 9 - Max: 12 DisplayThreadLimit=2 - Nvidia Thread opt: Auto Hyper Thread OFF
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=4 - Nvidia Thread opt: Auto Hyper Thread OFF
Frames: 120 - Time: 10000ms - Avg: 12.000 - Min: 11 - Max: 13 DisplayThreadLimit=6 - Nvidia Thread opt: Auto Hyper Thread OFF
5252.89 In reply to 5252.87
Hi PaQ, thanks for collecting that data!
Sort of... That data does seem to suggest that maybe it's better to use only half as many threads on a hyper-threading machine. Seems to be the opposite conclusion from some of Burr's previous data though.
I guess it's fairly likely that the optimal settings for different things (there are other internal variable factors too like number of buffers used per thread and vertex/index buffer size) is different on different machines depending on all kinds of factors like bus speed and video card speed, etc... and also probably even different on the same machine with different model structures as well.
5252.90 In reply to 5252.87
Hey PaQ,
Do you have another display script with the more detailed output from something previous?
"frames" + time
Thanks.
5252.91 In reply to 5252.88
Hi PaQ,
So it looks there that hyperthreading being turned on in the bios by itself doesn't harm anything but that there's not much to gain there by one thread per "virtual core", and that the increased contention ends up as a slight net negative.
This probably has to do with the whole process being memory bandwidth intensive instead of only calculation intensive which would suit hyperthreading somewhat better I think.
I think it will probably be best to go with a default of one thread per "real core" instead of one per "virtual core" for this particular thing.
5252.92 In reply to 5252.90
You're welcome, glad if it helps.
Hi Burr,
Not sure if I understand what you're asking.
I'm using fraps to benchmark the viewport (http://www.fraps.com/ ), with the autorotate2 script here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1001.1 .
5252.93
Using time display script in MoI....
1000 Spheres in Array (cube arrangement), mesh=5 deg.
2000 ms in prior version.
1069 ms in new version.
2x increase.
So it's good for larger shear quantity of surfaces. - when its more about large amounts of poly data being processed.
Not as much noticeable with simpler models. - when it's more an issue of the bottleneck with the PC communicating with the vid card.
In one case, when I was using a smaller number of objects. I noticed that the newer version was slower than the older.
5252.94 In reply to 5252.93
Hi Mike,
By very much or were they pretty close? But also with a small number of objects things are probably going at a fast enough pace that you probably would not be able to tell the difference if the numeric readout was not there, or was that not the case?
Show messages:  1-14  15-34  35-54  55-74  75-94  95-114  115-119
