MoI 1.0 is coming, so...
 1-8  9-21
525.9 In reply to 525.7
Hi JTB,
> Well, we obviously disagree on that. Can't say I 'm right but you're certainly wrong! :-))
> (just kidding). My limited as I often say experience makes it hard to change the way
> of working and thinking.
Well, let me put it this way - if you want to make a trapezoid shape and you have 2 lines, and every time you edit one line the other one also changes to match the same size, that will make it difficult to create a trapezoid, do you agree with that?
To make a trapezoid you want each line to have a different size.
> BTW, I discovered some problems with history that makes it very limiting.
Yes - the focus of History for Version 1.0 is mostly to allow fine tuning for the results of surfacing commands like revolve, loft, and sweep.
History is limited in many other areas than this right now. I don't expect history to be really improved from this for the 1.0 release of MoI - if history is very important for what you need to do, then probably some other software than MoI would be a better choice until some time in the future when MoI's history has the additional functionality that you need.
> 1. I make a curve and then 2 copies. I enable history and everything works OK.
> If I move one of the copies, the relation with the initial object, breaks.
This is because moving the copied object is in effect similar to deleting the copy and creating a new moved version of it. The deleting of the object is what breaks the history chain. Eventually there will be a way to preserve history in this situation but this won't be ready for V1.
> 2. History doesn't work with array command.
Yes, History doesn't work properly right now with some commands that generate multiple outputs from one single command such as array. I do expect to improve this in the future, but this will probably remain a limitation for V1.
525.10 In reply to 525.8
Hi Phlatt5th,
> A small suggestion from a newbie MoI fan :) Is there a way to have the
> icon for history change colors to identify when it is On or Off Michael ?
> This will let everyone know the status of the History feature. Sorry for
> giving you more work Michael.
Well, that icon is only kind of temporary. It will be there for V1 but after V1 I'll be trying to get rid of it. Instead there will be some kind of "Object properties" panel that will show some of the properties of the currently selected object, that will also include something for history updates on or off in that properties panel.
525.11 In reply to 525.10
Well thank you Michael for taking time out to respond, I eagerly look forward to the all that MoI has to offer. The beauty of MoI is something else, it enables people like me who is an artist without training as an engineer or architect . As a late comer to computer aided design (1998) I feel less intimidated and think less about software and more of design dreaming similar to working on a sketchbook prior to fabrication. I experience a somewhat similar feeling using SketchUp and learning Rhino, but I gravitate to MoI more consistently since I discovered it a few weeks ago. I believe that as MoI progresses in its development with things like dimensions, history etc. People like me who are middle aged and find myself on an adventure and loving it on the horizon of art, engineering, ID and architecture etc. can add this to our tool set like a pencil. Thanks to all the members of this forum who selflessly contribute by sharing their various talents, I am learning daily. thanks to all.
EDITED: 7 Apr 2007 by P5TH
525.12 In reply to 525.1
Umm... does anyone know how much MoI v1.0 is going to cost? As a starving student anything over $40 means I can't eat for the week. I'd hate to get hooked on the BETA just to be crushed with a $300+ program, and have to walk away. *sigh*
525.13 In reply to 525.12
Hi goney3 - well it is definitely going to be more than $40 - you can expect something around US $200.
525.14
About how far from the final 1.0 release are you now Michael ? weeks or months ?
/ Magnus
525.15 In reply to 525.11
Hi phlatt5th - Thanks, I'm glad that you are enjoying MoI! I'm very interested in making MoI feel like a comfortable environment where you get to focus more on your design and less on the software...
525.16 In reply to 525.14
Well, it's difficult to say exactly but probably a couple of months yet. I want to finish the software this month, but after the software is ready it will still take some time to finish up documentation and some other stuff. Hopefully that won't take more than another month to do, so maybe 2 months?
It seems like every time I try to predict how long something is going to take, it ends up taking 3 times along but I hope that won't be the case here.
525.17
Thanks for your reply Michael
Alright, that sounds good. Take the time you need and don't rush it, 2-3 months sounds resonable although i thought you'd need more than a month to wrap up the final stuff for the 1.0 release.
Hehe, it's tough to try to predict software developement like that. Better avoid doing that to not get a bunch of unhappy customers. :)
/ Magnus
525.18 In reply to 525.17
Well, basically I think whatever doesn't get done within the next month will just be postponed until the next version.
I want version 1.0 to be really good, but at the same time it already has quite a lot of useful stuff in it already... At some point I just have to stop adding stuff and just call that V1.
525.19
True that, you could keep on adding stuff until that day the universe implodes and then never get to release it. :)
Keep up the good work Michael. We're all waiting to see what you got in store for 1.0
/ Magnus
525.20 In reply to 525.19
Thanks!
Well, you've pretty much seen it already, it will be fairly close to the current beta release. I'm just trying to squeeze in a few more tools.
525.21 In reply to 525.20
My advice...
Don't give any more betas unless to fix something... Keep the new tools for the official release as a surprise. Just a few days earlier, release a features list
You will have more happy customers this way.
***There is always a better way to do things... Just find your Moment of Inspiration***
Show messages:  1-8  9-21
