How to Resize a Multitude of Similar Objects?
 1-11  12-31  32-35
5243.32 In reply to 5243.30
> Seems RotateObjects Rotate only in the vertical direction!
> Does it possible to have the other directions ?
Can you show an example of what you're trying to do? Maybe the node editor would be a good solution.
5243.33 In reply to 5243.32
Say in this case for any reason i want rotate all objects just after the explodeMove following the Y axis
But seems James gives us just the answer with the Node editor! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=10159.6
5243.34 In reply to 5243.33
Hi Pilou, also there is RotateObjects2 which allows you to pick the rotation axis either Top, Front, or Right views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8558.4
5243.35 In reply to 5243.34
Missed this one! Excellent!
So will be added in no time here! :)
Done: French version!
https://moiscript.weebly.com/rotateobjects.html
EDITED: 12 Feb 2021 by PILOU
Show messages:  1-11  12-31  32-35
