How to Resize a Multitude of Similar Objects?
 1-8  9-28  29-35
5243.29 In reply to 5243.13
Thanks so much for making ScaleIndividual! I just used it to resize over 5000 rectangular solids in a model of an LED display.
In this conversation, you had suggested that it would be easier to just delete all but one object re-make the array again. This wouldn't work in my case because what I had was not at all a simple array. I had solids that were rotated and positioned in a quasi-circular pattern that in no way can be quickly re-created. It would have been even more so if I had colored them yet. :-)
Thanks again.
Seems RotateObjects Rotate only in the vertical direction!
Does it possible to have the other directions ?
5243.31 In reply to 5243.30
The randomize one will achieve that. I think rotate objects was a "particular case" cookup....
5243.32 In reply to 5243.30
Can you show an example of what you're trying to do? Maybe the node editor would be a good solution.
5243.33 In reply to 5243.32
Say in this case for any reason i want rotate all objects just after the explodeMove following the Y axis
But seems James gives us just the answer with the Node editor! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=10159.6
5243.34 In reply to 5243.33
Hi Pilou, also there is RotateObjects2 which allows you to pick the rotation axis either Top, Front, or Right views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8558.4
5243.35 In reply to 5243.34
Missed this one! Excellent!
So will be added in no time here! :)
Done: French version!
https://moiscript.weebly.com/rotateobjects.html
EDITED: 12 Feb 2021 by PILOU
Show messages:  1-8  9-28  29-35
