Dividing surfaces with curves?
All  1  2-4
better if you post the 3dm file ;)
Trim and "keep" and copy move the face ? You can after make some extrude following direction inside the sphere etc...
Depending of what do you want exactly, view inside the sphere or not etc...
EDITED: 29 Jun 2012 by PILOU
5220.3 In reply to 5220.1
Hi Dreamcube017 - yup like Pilou says you want to use the Edit > Trim command for that kind of surface-level cutting. It will slice only the surface of your object up into pieces instead of working at a solid volume level like the booleans are targeted at.
See here for a previous example similar to what you are describing and some description on how to use Trim:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
5220.4
Aha! I knew there was a tool for doing this! Thanks!
Show messages: All  1  2-4
