Dividing surfaces with curves?
5220.1
Hello. Just checking out the ptrogram and it's really awesome.
The only problem is that I've project some curves onto a sphere and would like to have the surfaces seporated. For example, in the image, there's a polygon projected to a sphere. I'd like the face of the polygon to be separate so that I can do things such as insets and stuff, but I can't seem to figure out what I'm doing wrong. I've tried a few of the booleans which sort of work, but don't give the exact results I am looking for.
Here's the image.
http://content.screencast.com/users/Dreamcube017/folders/Jing/media/5756b4bb-7824-42b4-8161-e067ca94494e/MoI%20cutting%20shapes.png
Thanks.
better if you post the 3dm file ;)
Trim and "keep" and copy move the face ? You can after make some extrude following direction inside the sphere etc...
Depending of what do you want exactly, view inside the sphere or not etc...
EDITED: 29 Jun 2012 by PILOU
5220.3 In reply to 5220.1
Hi Dreamcube017 - yup like Pilou says you want to use the Edit > Trim command for that kind of surface-level cutting. It will slice only the surface of your object up into pieces instead of working at a solid volume level like the booleans are targeted at.
See here for a previous example similar to what you are describing and some description on how to use Trim:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
5220.4
Aha! I knew there was a tool for doing this! Thanks!
