WebGL and MoI.....Maybe?
All  1-11  12-18
5219.12
Still not convinced about WebGL coolness ? Then I guess you have to click http://madebyevan.com/webgl-path-tracing/
5219.13
also check http://p3d.in/ another WebGL-based 3D viewer.
5219.14
Michael since they have a plugin Rhino do you think it maybe easier to cook one for MoI also?
Since 3D PDF export support is not likely to happen for MoI, that maybe a good alternative, NO?
5219.15 In reply to 5219.10
Hi adamio, have you been using it yet? Is it working well for you, have you actually used it to send information to someone else?
How does the editing part work - do you know if Sunglass takes actual CAD data like 3DM, STEP, or IGES files or does it only work with polygon data only?
> When I posted this my only thought was; It'll be cool to have a Web collaboration viewer
> for MoI, since Sunglass was releasing the API.
Ok, but can't you use MoI with it already? It seems to say that it has integration with Dropbox - does that mean that if you save a model file into a particular folder in Dropbox that it will auto upload that? If that's the case then just save from MoI into that one particular folder and then BAM! you're using MoI with Sunglass right there, aren't you?
What is it in particular that you hope to gain by a plug-in instead of that?
That's definitely cool! Cool and useful are fairly different things though.
How is it going to work to use WebGL for a viewer when WebGL does not function at all on Internet Explorer or the iPad?
Not really - MoI does not implement Rhino's plug-in interface, MoI only implements a file reader for reading the Rhino 3DM file format. File formats and plug-in APIs are pretty different things.
It might be as long as you know the person receiving it does not use Internet Explorer.
I don't understand why you make it sound like you can't use MoI with it already though - can't you just upload files you generate from MoI using one of their general purpose file upload tools?
Why is it that you think that a special plug-in is required in order to just upload a file to their service?
What is the big difference between GrabCAD and other ones ?
Works fine in Chrome, Firefox, Safari
Seems it don't make yet the convert of files, you must send your file in different formats ?
See some models inside the 3Dspace without problem :)
I donwload without problem inside Moi some Model and put some joyous color with the script by Michael ;)
script: /* Radom Styles to solids*/ var styles = moi.geometryDatabase.getObjectStyles(); var breps = moi.geometryDatabase.getObjects().getBReps(); var style_index = 0; for ( var i = 0; i < breps.length; ++i, ++style_index ) { if ( style_index == styles.length ) { style_index = 0; } var brep = breps.item(i); brep.styleIndex = style_index; }
Model and video by Nayla Miana http://grabcad.com/nayla.miana?page=1
EDITED: 30 Jun 2012 by PILOU
5219.17
Update, Sunglass is out of Beta.
https://sunglass.io/
5219.18
Hello,
Creators of content usually want to hold ownership over the content until complete (and the check doesn't bounce). I think it's a bit of a stretch to say this is a serious collaborative technology. Aside from the whole data mining issue, there is no such thing as "web based" and "secure". I also think it's a point solution in that there are specific files that can be placed in the framework, with that limitation companies cannot get the complete project picture. I can see a group screen share with a call bridge being more effective and secure than this technology. If your security and auditing requirements are more strict there are existing solutions that handle that quite well. I do tinker with the VSR WebGL plugin for Rhino, if I was going to send something out I'd use that before 3D PDF.
Show messages: All  1-11  12-18
