Getting a curve to follow a shape that tapers?
All  1-6  7-10
5208.7 In reply to 5208.6
Cool approach Fabien!
And yeah if you project the curve onto the dome first, then when you twist it the twisted result will still hug directly along the surface if the surface is a surface of revolution and it has the same axis of rotation as the twist axis.
Because with an exact surface of revolution if you rotate any point that starts on the surface around the same axis, the ending point will also be on the surface too since it has that radial symmetry...
I'm still getting used to all the possibilities opened up by Twist and Flow myself! :) Definitely helix-ish stuff and Twist are friends.
5208.8
Wow thanks guys for your input I'll be trying these later on.
Lang
5208.9 In reply to 5208.8
Hi Fabien
Would you mind giving me a more detailed description of what your doing with that twist method as I can't work it out.
I've tried the drawing the curve directly onto the dome that works well, thanks Michael, but I'm having all sorts of problems getting the sweep right. I see what you mean about how hard that may be to get right.
Thanks guys
Lang
5208.10
Hi all
I've been playing around with the twist and sweep function and am getting there I think. Still not perfect but may be good enough for what I need. I sweeped the curve with 3 different circles as these work quite well around the tapering shape of the dome. No matter how I do it otherwise I can't seem to get say an oval to work how I want it so maybe one of you more experience guys out there can help me out on that one?
I have another issue going on here with the file attached. Basically I can't fillet the edges around the sweeped boolean shape to soften the edges and have come across this problem a few times. The object is unified and joined so don't know why it won't fillet. I've also tried using a very small fillet amount to begin with but that won't work either. I reckon its going to be something really simple no doubt that I'm missing here.
Thanks again for any advice here folks
Lang
Show messages: All  1-6  7-10
