bending curves
5201.1
hi all
I try to bend an arc (black) around another arc (blue). The problem is that it always rotates 90° instead following the blue curve (green).
Has anyone an idea howto achive this?
Thanks for any hints
nos
5201.2 In reply to 5201.1
hi there..
funny enough, if you rotate the whole assembly by 90°, everything is working as expected..
5201.3 In reply to 5201.1
Hi nos, this has to do with the starting normal being chosen differently from the vertical line and the arc - basically curve flow works similar to sweep and there is an x/y/z axis frame that slides along each curve. In this case the starting x axis direction is being chosen differently for each curve, so that's what produces a different result.
That is something that I should be able to tune up, I've added it to my list of things to tune up.
In the meantime if you rotate the whole thing down to the world x/y plane it should then work ok for you, see attached file.
