Optimally Ordered Antipodally Symmetric Point Set Generator, also Non-Antipodal. For unit sphere. Import the point files
 1-18  19-22
5199.19 In reply to 5199.17
It is kind of weird that other files did work ok for you though. Anyway tomorrow I will investigate and try to see what's going on there.
5199.20 In reply to 5199.19
.Deleted irrelevant post.
EDITED: 22 Jun 2012 by BEMFARMER
5199.21 In reply to 5199.17
Hi Stefan, I've been investigating this import point file problem today and it seems to be a bug pretty deep in the scripting system involving conversion of string values to number values. It's also not unique to the Mac version, it happens on the Windows version too.
I'm working on a fix to the script engine itself for the next v3 release, but in the meantime here is an updated ImportPointFile plug-in which has a slight modification which will avoid triggering this particular bug, this version should work for you with your original locale settings, please let me know if it still does not.
5199.22 In reply to 5199.21
works fine now! Thank you very much for the quick fix, much appreciated!
Show messages:  1-18  19-22
