Optimally Ordered Antipodally Symmetric Point Set Generator, also Non-Antipodal. For unit sphere. Import the point files
 1-15  16-22
5199.16 In reply to 5199.15
I just checked and this is my locale settings:
5199.17 In reply to 5199.16
i switched my locale settings as a test to United States and now MoI displays Ben's 50points file properly.
I must admit i never had this problem before on my Mac.
5199.18 In reply to 5199.17
Hi Stefan, the locale can have an impact on how numbers are parsed with certain kinds of parsing functions.
Somewhere in there is a bug that numbers are being parsed with a locale-specific handler when it should not be.
Thank you for posting your settings and for testing with altered locale to narrow down the problem, that should let me reproduce it over here and investigate a fix.
5199.19 In reply to 5199.17
It is kind of weird that other files did work ok for you though. Anyway tomorrow I will investigate and try to see what's going on there.
5199.20 In reply to 5199.19
.Deleted irrelevant post.
EDITED: 22 Jun 2012 by BEMFARMER
5199.21 In reply to 5199.17
Hi Stefan, I've been investigating this import point file problem today and it seems to be a bug pretty deep in the scripting system involving conversion of string values to number values. It's also not unique to the Mac version, it happens on the Windows version too.
I'm working on a fix to the script engine itself for the next v3 release, but in the meantime here is an updated ImportPointFile plug-in which has a slight modification which will avoid triggering this particular bug, this version should work for you with your original locale settings, please let me know if it still does not.
5199.22 In reply to 5199.21
works fine now! Thank you very much for the quick fix, much appreciated!
Show messages:  1-15  16-22
