Rounding/Conversion Error in Viewport
All  1-8  9-10
5196.9 In reply to 5196.7
Oh now that I checked, it turns out that the updated UI files that I posted previously only disable the rounding for "feet & inches" type display, not decimal type numeric display. I'll post another update here a bit later that will disable the rounding of larger values for decimal numeric display as well.
5196.10 In reply to 5196.7
Hi FDP - attached here is an update for the current v3 beta which should actually disable the additional rounding on decimal values of 100 or greater, to update your installation copy the attached file over top of the old version which is inside of the \ui folder inside of MoI's main installation folder.
Let me know if you are using v2 instead of the v3 beta, on v2 it's a slightly different file that needs to be updated.
Show messages: All  1-8  9-10
