MoI v2.5 Mac OSX final version released!
 1-10  11-30  31-36
5191.11 In reply to 5191.1
Thanks a lot. It feels good to have a final release.
Message 5191.12 deleted 19 Jun 2012 by BURRMAN
5191.13 In reply to 5191.1
I wish to congratulate you for the hard and wises work that you have been able to realize this mac OSX version
also I wish to inform you that I'm already developing great work from it in my area where I reside in Saint-martin French Caribbean Island
long life to MoI :)
Thierry
5191.14 In reply to 5191.1
I just purchased the Mac version! Thanks so much, I've been using the beta for a bit over a month, and it has been a great addition to my C4D workflow! So great to have an affordable NURBS modeler on OSX!
5191.15 In reply to 5191.14
Thank you Sean!
5191.16 In reply to 5191.12
>>>> Hahahaaaaa.
Oh this was suggestive BurrMan?
My mother language is German so be prepared for more unintentionally written strange/funny thing from me :-)
5191.17
Congratulations for this release Michael !
Welcome to Mac OSX users ! :-)
Happy MoI user since beta version of August 13 2006...
5191.18 In reply to 5191.1
is it possible to get a 64bit version?
i have large IGES files and must convert them in OBJ for big displays. With a fine mesh output MOI3D says there is not enough memory. I have 14 gigs RAM in my OSX workstation here...
btw. same file with open beta -> no problem when i converted it to .OBJ
5191.19 In reply to 5191.18
Hi Chico,
Sorry, but no it's not likely anytime soon as there is a lot of additional work involved to produce that.
See here for more details:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5172.5
The easiest solution is to select something like half your objects and then use File > Export to export just those objects to a file and then invert the selection and do the rest to a separate file. Then in your render program import both of those files.
The "Export" command is short for "Export selected" - it writes out only the selected objects to the generated file instead of everything and doing that should help to reduce peak memory consumption.
Also you can lighten the memory load somewhat by changing a setting to use a rougher display mesh, that's a setting under Options > View as described here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4643.2
Setting the "Mesh angle" to a rougher angle like 25 degrees and unchecking "Add detail to inflections" will make for a somewhat rougher looking display but also lighten up the density of the display meshes and that can help reduce memory consumption by quite a bit on more complex models.
There is nothing changed in this area since the open beta to the release version, so that's kind of odd. But it is possible to get that behavior with things that were just barely fitting within available memory space, if you have done anything different at all like opened other files within the same program session that can possibly lead to "memory fragmentation" and give you a slightly different result than a fresh program run.
5191.20 In reply to 5191.19
I got this message:
My system Date it is Ok, i disable firewall, I did trash the app, redownload, and make a fresh install/run with the same result, so i can't figure what is wrong.
Any Ideas?
For the records, I had no issues with beta test versions,
Luis G.
Macbook pro i5, 8gb ram, Osx Lion 10.7.4
5191.21 In reply to 5191.20
Hi Luis, you're getting that with the trial version not the actual final release version, is that correct?
I think there is probably some conflict with the very initial released beta version.
The public beta version has not expired yet so you can continue to run the public beta for now.
5191.22 In reply to 5191.16
""""""""My mother language is German so be prepared for more unintentionally written strange/funny thing from me :-)"""""""""""""
You did great Martin. I knew what you said... Just to be sure, my "hahahhahaaaa" wasnt "at you".... I could have done without making my post. I'm going to delete it because it doesnt belong.
5191.23 In reply to 5191.21
Michel,
Correct, I got this error with the trial version.
Luis G.
5191.24 In reply to 5191.23
Hi Luis, I've sent you a private message.
5191.25 In reply to 5191.21
Hello, I'm having a similar problem with the trial complaining about a clock mismatch. I messed with the MoI beta for a couple months on my previous computer-- a few days ago I got a new Macbook Pro (completely fresh install, no migration) and stuck the last beta (Jun 1st release) on it, which I think I opened once. I'd really like to give the trial a shot; any chance of some kind of workaround? Oh, I am running Mountain Lion DP4, so perhaps the issue is related to that. Anyway, I'd be happy to help diagnose; I'm eager to check out the final version!
Will
5191.26 In reply to 5191.25
Hi Will, there's really no difference between the 30-day trial version and the last public beta, so you can just continue to run that last public beta for the moment instead of the trial. There seems to be some problem with the 30-day trial right now where it gets confused on some people's machines. I will be looking at reworking it slightly to try and avoid that.
The actual full release version (the purchased one, not the trial) does not have any kind of expiration mechanism in it at all and so it is not affected by that problem.
5191.27
Congrats, Michael, a lot of folks have been asking for this, nice to see it finally coming to fruition!
-Will
5191.28 In reply to 5191.1
Great timing! I had not really followed this effort too closely, since I use Windows almost exclusively. But my new Macbook Pro Retina is arriving soon, so suddenly this seems very interesting indeed. I'll be sure to give this a try shortly...and thanks for the dual licensing Michael, very classy of you as always.
- Dave Morrill
5191.29 In reply to 5191.28
Hi Dave, there are some issues with MoI on the new Retina Mac - Apple has introduced a new mechanism there where it basically lies to some apps and tells them that their window is only half as big as it really is so and then displays it as doubled up in size in order to avoid making things like controls too small on the screen.
Right now they did not seem to include any method to turn that mode on or off for every kind of app, so you will probably end up with MoI looking kind of weird and blocky since it will force it to use that "half size and then stretched up" display method.
You can avoid that if you set the screen to the real full resolution, and you need to use a separate utility to do that since Apple decided to not include that in the regular display settings, see this thread for some info:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5211.1
So anyway that will be one issue that you will see on that one particular Mac model right now.
5191.30
Just got my license through for the program;
Thanks again Michael for making this available for mac users.
I'm sure all the hard work will be worth it.
Show messages:  1-10  11-30  31-36
