Selecting connecting objects to hide
All  1-3  4-6
5186.4 In reply to 5186.3
If you clcik the outside bottle, and hide it, then there are your objects. If you window select the top area, it will select just the shape that is fully enclosed in the window selection. If you look in the top of the bottle, (Where the 2 surfaces meet) you can zoom up just a bit and note that you really can select just the inside shape. The larger outside one takes precedence from a distance. In the objects area where you have named the outside, you can hide that with the scene browser.
5186.5 In reply to 5186.3
Hi Lang, thanks for posting the file - and yes like Burr mentions above usually your best bet for such things when some piece is getting in your way is to select that piece and hide it so that you can then more easily work on other things without that getting in your way.
If you are struggling with selecting things, it's usually a sign that hiding some things would help - it's kind of a good habit to use hiding frequently, don't hesitate to do it otherwise you can waste a bunch of time.
Also a strategic use of window select can also work well to grab interior objects when you start the window on the left and drag it towards the right only objects contained entirely inside the window will be targeted. See here for an example of using that to select interior objects:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1810.2
But it probably is easiest to just select the outer one since that is the easiest one to click on and then hide it so that it won't be in your way anymore temporarily.
5186.6 In reply to 5186.5
Thanks guys. Great to see you've now released the mac version too.
Show messages: All  1-3  4-6
