Rotate Array Elements
All  1-10  11-15
5176.11 In reply to 5176.10
> It's not possible to have a Copy + Rotation ?
It could be possible, but "rotation" is a pretty generic term - rotation actually happens around some particular axis.
From what Sharif described it sounds like he was looking for rotation around a curve tangent, but I'm not 100% certain.
> You choose your object to copy and then at each click this one is
> copyed with an incremented rotation :)
Rotation around what though?
5176.12 In reply to 5176.7
Hi Michael;
Thanks for explanation, indeed both of those tools are powerful and great! I have used them both and you can see some examples @ (www.atelier424.com).
-sharif
5176.13 In reply to 5176.11
Rotation around the Z axe is sufficient
One click = select object(s)
Input Degre of rotation
One click on the object(s) for position of this vertical axe of rotation and base point for the insertion point
then the copy + rotation can begin :)
At a click in the empty 3D space the object is drawn under the cursor
Little video by Sdmitch http://sdmitch.blogspot.fr/
EDITED: 7 Jun 2012 by PILOU
5176.14 In reply to 5176.13
The Array Circular command can actually be used currently to copy an object by one step in z and also do a rotation around z, set the "vertical step" option as shown here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4464.12
5176.15 In reply to 5176.14
Yes but can't click anywhere you want at each click ;)
Despite of the fact that you put them on any curves or surface with crazy rotations
It's an easy way for make a sort of controled randomise placement objects without effort!
All is made only with this function!
EDITED: 22 Jul 2019 by PILOU
Show messages: All  1-10  11-15
