Triangular Pyramid with rounded ends.
Made a triangular pyramid.
Used nested G2 blends of half arcs.
The tiny center curved red triangle is with network which may be a bit distorted.
Is there an easier way?
EDITED: 2 Apr 2015 by BEMFARMER
5161.2 In reply to 5161.1
Hi Brian, you might try something more like - draw in a profile curve:
Revolve that with "Cap ends" off to make a rounded surface like this:
Select the pyramid and use Boolean difference with that revolved surface as the cutting object - that will chop off the point of the pyramid which you can delete:
Now the rounded surface is imprinted into the tip and to make it be connected smoothly to the side faces select the top face:
And then use Construct > Fillet to make smooth connection pieces:
So basically try to more directly model the rounded tip shape and let it be initially sharp where it hits the pyramid, then use filleting to smooth it.
5161.3 In reply to 5161.2
Thank you Michael.
