Different Blend at Endpoints?
5160.1
Hello,
Is there a way to Blend two separate curves with one endpoint at G3 and the the other end at G2? Thanks.
5160.2 In reply to 5160.1
Hi OSTexo, no there's currently no way to do a different continuity setting for different ends of the blend curve.
But a G3 blend is also G2 as well, so if it is specifically curvature continuity that you're looking for doing a G3 blend will give that.
5160.3
Hello,
Thanks for the info. I have a need for that function, I found a plugin that will do that with Rhino.
