PET Bottle?
All  1-9  10-12
5147.10 In reply to 5147.9
< just roughly blocked out some shapes and then applied a fillet.
That is the secret !
5147.11 In reply to 5147.9
Hi TwinSnakes, that's great that method is clicking!
It takes a while to get used to it - basically when you look at a shape and there is some mixture of broad shapes and then some more tightly bent areas try to temporarily ignore the tightly bent transition areas since those are indicative of fillets.
The other kind of thing is not getting too focused on building surfaces that directly hug to some irregular outline - usually you want to build an extended surface and then cut it rather than trying to construct the surface initially to such an outline. That kind of thing with visualizing extended areas of the model earlier on in the process can sometimes take a while to get the hang of as well.
5147.12
Many thanks for your help. I am very grateful for the solution paths
Show messages: All  1-9  10-12
