View / Image visibility
5143.1
IS it possible to have 'hide all' & 'show all' in the View / Image pop-up? I work with multiple images in a file and this would speed things up (a bit!)
Thanks...
5143.2 In reply to 5143.1
Matt,
This one allows you to toggle the viewing of objects you currently don't have selected:
 script: /* Isolate selection */ moi.geometryDatabase.isolate();
Very useful.
5143.3 In reply to 5143.2
Hi Mike, This one I know. This was for inserted images on the view / image button. Turning all off or on... Any ideas?
5143.4 In reply to 5143.3
hi there
i'm not quite sure what you are looking for, but this script will hide all visible / show all invisible background images.
http://kyticka.webzdarma.cz/3d/moi/#HideBI
script:var images = moi.view.getBackgroundImages(); for ( var i = 0; i < images.length; ++i ) images.item(i).hidden = !images.item(i).hidden;
~ marco
5143.5 In reply to 5143.1
Hi Matt, that script that Marco shows can work on a shortcut key when you're not even in the Image command at all so that could be useful.
But also to help with managing things with more images while inside of the Image command I've added a right-click function so that right-clicking on the "Show/Hide" button will apply the action to all images instead of just the currently selected one like it will with left click.
To get the updated image command, copy the attached Image.htm file over top of the old version in your \commands sub-folder inside of MoI's main installation folder.
Hopefully that will help out some too.
5143.6 In reply to 5143.5
Thanks everyone, just what I needed...
