Hotkey and UI requests
 1-20  21-35
5141.1
Good day Michael,
When and if you have time could you look into the following 3 requests?
1. Having set up a hotkey for 3D view, I am constantly needing to switch between Perspective and Parallel views.
I can only do so by going to: Options>View>3D view projection>selection window. I searched the forums and hotkey/script
sources but was not able to find something that worked. Is it possible to set up separate hotkeys for each for these views?
2. Would it be possible to break up the Reset command so that the 2 actions in that command could be assigned to separate hotkeys?
In other words: one hotkey for “zoom extents” and another hotkey for “zoom selected”. I am constantly tripping over myself, never
being able to remember whether I previously hit the Reset hotkey once or twice.
3. Would it be possible to allow for color options for the yellow preselection and selection color? Although there is variation in color
value, I find myself confusing them. Yellow seems to be a difficult color for me. The ability for color option would be helpful.
(Perhaps this last request would be better placed in the V3 requests thread.)
Rich
5141.2 In reply to 5141.1
Hi there!
..regarding 1.
Parallel view:
script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel';
Perspective view:
script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Perspective';
Toggle Perspective / Parallel:
script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = (vp.projection == 'Perspective' ? 'Parallel': 'Perspective');
~ Marco
EDITED: 19 May 2012 by MARCO
5141.3 In reply to 5141.2
Thank you, Marco.
I had previously tried the 2 scripts you listed for Parallel and Perspective, and they do work. However, if you are in any of the ortho views (top, right etc.) the scripts do
not work unless you first hit the 3D button or hotkey. This is not the problem if you are going from Parallel or Perspective to any of the ortho views.
Rich
5141.4 In reply to 5141.3
Hi Rich,
> scripts do not work unless you first hit the 3D button or hotkey.
Hi Rich - those scripts should work no matter which view you are in to start with, but the script only manipulates the projection of the 3D view so you will only see the result of the script when you actually make the 3D view visible by going to either Split view or 3D view mode.
If you are in maximized Top view for example, then when you trigger that script yes you won't see any change because it's only changing the 3D view's projection and that view is not being displayed right then.
Were you expecting for the Top/Front/Right ortho views to switch to a perspective projection instead? That's not possible - those ortho views are only set up to display a parallel projection, it's only the 3D view's projection that can be altered to either parallel or perspective.
If you want something like a "Front perspective view", it is possible though to get that view by setting the 3D view to be perspective and then orienting it so that it is looking in the same direction as the Front view, you can set the 3D view to some specific direction by using the Options > View > 3D view angles dialog, and it is also possible to set these by a shortcut key script, see here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=701.3
5141.5 In reply to 5141.1
Hi Rich, re: #3 -
> selection color? Although there is variation in color value, I find myself confusing
> them.
There are some settings in moi.ini that control the selection color. To edit moi.ini go to Options > General and push the "Edit .ini file" button.
Then in the .ini file find the [View] section and find these settings:
LineSelectedColor=255,255,32
SurfaceUnselectedTransitionColor=255,255,208
SurfaceSelectedTransitionColor=255,255,128
SurfaceSelectedColor=239,239,0
These are all red,green,blue color values with each value ranging from 0 to 255, so 0,0,0 is black, 255,255,255 is white, and other colors are different mixes of red green and blue. You should be able to use the color picker in a bitmap editor program to see the r,g,b values of different colors.
The "transition" ones are used for the hover colors, see here for some more notes on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1004.15
http://moi3d.com/forum/index.php?webtag=MOI&msg=1004.17
5141.6 In reply to 5141.1
Hi Rich re: #2 - zoom selected / zoom everything - I'm sorry I don't quite follow what's tripping you up on that one...
Those are not broken out to script as separate functions, just one "reset" function.
But it toggles between selected and everything every time you trigger it so it doesn't really matter which one you pushed last, just watch the screen as you trigger it and if you do not go to the one you want at first just trigger it again and then you will be there.
Also if you adjust the view in any way by any kind of pan, zoom, or (in 3D view) rotate, then the next reset will target selected objects.
You'll only get zoom to all on the first click if you previously did zoom to selected and have not adjusted the view in any way since that last time. Normally there is a lot of view adjusting going on while modeling, so typically the first press will do a zoom selected.
Is the problem that you're trying to do a super fast "double click" on the button or something like that? Don't do it like that - click it once and watch what you get and if it's not what you wanted then click again.
5141.7 In reply to 5141.6
Michael,
re: #1-
Yes. I did not realize that Moi3d is designed with the separation between 3D and Ortho views as you describe.
Since I almost always work in a single viewport, I was hoping that I could set my hotkeys up to duplicate
my workflow from other programs, ie. top view to perspective to side view to parallel to front view etc. In short, yes, I had
hoped to hotkey back and forth without having to select the 3D button. Since this is not possible, I will adjust.
I would prefer to work in Perspective and never use Parallel except that Parallel allows closer and more controllable zooming.
re: #2-
This is the thing that trips me up. It loses control over the rotation about the selection.
If I select something, hit reset to zoom in, rotate around the selection, make a pan for a slightly different
view the center of rotation around the selection is lost and my desired selection spins out of my field of view when I again rotate.
I then have to begin all over again.
This is really related to a thread by 3DKiwi:
http://moi3d.com/forum/index.php?webtag=MOI&final_uri=discussion.php%3Fwebtag%3DMOI%26amp%3Bright%3Dsearch
I believe what was being asked for is inherent in my request, to zoom to selected but not to lose rotation about selected so easily. This is
invaluable when working on small detail, and is not solely poly modeler behavior.
re: #3-
Beautiful! Just what I was looking for.
As always, thanks so much for your spontaneous and precise responses.
Rich
5141.8 In reply to 5141.7
Hi Rich,
re #1,
Yeah the ortho views are oriented more for 2D work and also have some special 2D behavior activated when you use them instead of the 3D view. For example when you're in a 2D view you always will get an a 2D edit frame surrounding your selection in that view which you can use to quickly scale or rotate the selected objects. You'll only get that in the 3D view if the selected object is itself planar.
Also when you draw in an ortho view, the points that you pick will be projected on to a plane going through the first point that you pick, so that the drawn result is totally planar. In the 3D view points and snaps are freely placed in 3D which can be useful if you want to draw non-planar shapes. So anyway, things are generally set up that MoI assumes that when you're working in an ortho view that you are doing 2D work and has behavior to help that type of work out, and when you're in the 3D view it assumes that you're doing 3D oriented work and want to more freely place points and object rather than strictly forcing them to be planar.
> I could set my hotkeys up to duplicate my workflow from other programs,
It is possible to set up shortcut keys that switch between different maximized viewports with one keystroke, see here for some scripts that do that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
So if you want to just set up a shortcut key that will do the same thing as clicking on the different view modes tab buttons, the scripts shown there will do exactly that...
It would also be possible to make a combination script that would both switch to the maximized 3D view as well as set it to parallel or perspective all with one keystroke, let me know if you need help setting that up.
But yes the Top, Front, Right, and 3D viewports are all separate viewports each of which has its own settings like its own camera view and zoom factor, etc... but it's only the 3D view that can have an arbitrary view direction and can be set to a perspective projection. When you click on those buttons like "Top/Front/Right/3D", you're switching which of those viewports is the maximized one taking up the whole working area, the actual other viewports are still there but just hidden until you switch back to it or switch to split mode which shows all 4 at once.
One other note is that the Top/Front/Right ortho views can be relocated to some other frame of reference by setting a construction plane (View > CPlane) - when you set up a cplane there is an option at that time to either have the ortho views stay looking along the world axis directions, or whether they should become views that are relative to the new cplane.
I thought what you were asking for previously was just a way to do the "zoom extents selected" or "zoom extents all" as different keystrokes - I'm not following this new part about differences in rotation behavior on top of that, isn't that a different thing?
> a pan for a slightly different view the center of rotation around the selection is
Yeah when you pan away, the rotation pivot point pans along with you. Otherwise if it just stayed where it previously was it would be pretty easy to pan over a ways and actually have your rotation pivot point somewhere way far off of the screen from where you are currently looking at. At that point your rotation would spin really wildly since it was based off of some point that you're not even currently looking at.
Aside from using view reset, you can also place your rotation pivot to a specific location by using the Zoom Area button on the toolbar at the bottom of a viewport. That lets you pick an area to zoom into and the center point of that area can be picked with an object snap and the point you pick there will become the new rotation pivot point.
EDITED: 19 May 2012 by MICHAEL GIBSON
5141.9 In reply to 5141.8
Good day, a new day, Michael,
I spent some time last night rereading your last reply. I feel that I have not expressed myself
clearly and that we are to some extent talking to cross purposes. I know all of what you explained,and
am worried that I am causing you to waste your time that would be better spent elsewhere.
Let me try to simplify my requests, starting with the following:
Yes. I would like to set up two hotkeys. One that would both switch to the maximized 3D view as well
as set it to parallel. And another that would both switch to the maximized 3D view as well as set it to perspective.
And second:
>as different keystrokes....
Yes. Two separate hotkeys: "zoom extents selected" and "zoom extents all".
If these requests are possible, bless you.
If not, bless you anyway; your software is a marvel and I thank you for it and you time.
Rich
5141.10 In reply to 5141.9
Hi Rich, here are some scripts that you can assign to shortcut keys that I think handle what you are asking about:
Sets maximized 3D view and sets the 3D view's projection to perspective:
script:/* Set perspective 3D view */ moi.ui.mainWindow.viewpanel.getViewport('3D').projection = 'Perspective'; moi.ui.mainWindow.viewpanel.mode = '3D';
Sets maximized 3D view and sets the 3D view's projection to parallel:
script:/* Set parallel 3D view */ moi.ui.mainWindow.viewpanel.getViewport('3D').projection = 'Parallel'; moi.ui.mainWindow.viewpanel.mode = '3D';
Zoom extents to select objects only (will not switch to zoom all if triggered a second time):
script:/* Zoom extents selected */ var vp = moi.ui.getActiveViewport(); vp.zoom( 0.9 ); vp.reset();
Zoom extents to all objects only (will not switch to zoom selected if triggered a second time):
script:/* Zoom extents all */ var vp = moi.ui.getActiveViewport(); vp.zoom( 0.9 ); vp.reset(); vp.reset();
Let me know if you have any problems with those.
5141.11
...slightly related...
Michael, was there ever an update that you know of for the "FullScreen" script that allows for the UI to be toggled on and off?
The one I have doesn't work for V3.
5141.12 In reply to 5141.10
Oh happy day!
Installed. They work beautifully. So simple, so precise; yet incomprehensible and impossible to achieve for
a script-illiterate like me.
Btw, in regard to my UI color request: there is a color picker in Moi3d. Options>View>Color>click on any color
window and you have an RGB color picker. Select your color modification, copy and paste the readings into the .ini file.
Saves the trouble of going to Photoshop etal.
Thank you.
Rich (a happy moier)
5141.13 In reply to 5141.12
Rich,
Here are two different flavors of "parallel" view:
Here is Parallel view at that 30/60 degrees thing... "Dimetric"
 script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; var as13 = Math.asin(1/3); vp.setAngles( 90 - (Math.asin(Math.tan(as13)) * 180/Math.PI), as13 * 180/Math.PI );
Here is a Parallel view at 45 degrees... "Isometric"
 script:var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = 'Parallel'; vp.setAngles( 90 - (Math.asin(Math.tan(30 * Math.PI/180)) * 180/Math.PI), 45 );
And to get things back in Perspective...
Really good for when you're trying to get that "old school" look.
EDITED: 21 May 2012 by MAJIKMIKE
5141.14 In reply to 5141.11
Hi Mike - re: FullScreen for V3, check out here:
<....> Note -
And Rich - you're welcome and I'm glad those scripts are working for you!
EDIT: note - the full screen version linked to previously didn't work quite right if you had the scene browser in "inside" mode, see the updated one a bit further down in this thread for a fixed version:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5141.17
EDITED: 21 May 2012 by MICHAEL GIBSON
5141.15 In reply to 5141.14
Thanks Michael,
Found out that V3 doesn't seem to like the ".js" on the end of "FullScreen.js" for a key command.
But I don't know why or why not it was there. I'm guessing it didn't care in V2.
Okay, noticed a problem with FullScreen.js - on first activation it adds a large blank area to the left of my command pane (which is on the right).
The next activation clears the UI and does what it's supposed to do. The next activation still comes back with the added panel.
You have to re-load MoI to get get rid of it.
5141.16 In reply to 5141.15
Hi Mike,
What are you putting in for the shortcut? Are you maybe starting it with script: at the front of it? That prefix script: is actually only meant to be used when the script code itself is directly in the shortcut, when it refers to a separate .js file don't put script: in the front, just put the whole path to the .js file like: c:\scripts\FullScreen.js . It will also try to automatically add the .js when it checks to see if that shortcut is actually a file that can be loaded though too.
It's probably something to do with the scene browser pane - over here I don't get a blank area but it does show the scene browser pane even though it's supposed to be turned off.
Do you get normal operation if you turn the browser pane on before doing FullScreen ? Or do you maybe have the browser in "inside" mode?
5141.17 In reply to 5141.15
Hi Mike, so it looks like FullScreen did not work quite right with the scene browser in "inside" mode.
I've attached an updated version of FullScreen.js which I think should fix that up.
Copy the FullScreen.js somewhere on your system and then for the shortcut key put in the full path (and only the full path, no "script:" at the front) to the file, like: c:\scripts\FullScreen.js
5141.18
Thank you very much, Michael!
Yes, I keep the browser inside.
It works again! ...kind of...
So it does hide the UI, effectively enlarging the current window scheme to full screen, however:
On the first activation it will not hide the UI, but only closes up any expanded open tool options.
On the second activation it will hid the entire UI.
Then after that will will then both hide the UI and close any expanded tool option simultaneously.
5141.19 In reply to 5141.18
Hi Mike, could you describe a bit more exactly what you mean by "expanded open tool options" ?
Do you mean options for a command that is currently running?
Are you running it under version 3 or version 2? I've been testing it under v3 and I can't seem to get the behavior you are describing, does it only happen to you in v2?
5141.20
Using V3's beta.
It's the sub-palette that carries more tools. Life for "Boolean" you get the layout that has the icons for "Diff", "Union", "Isect", & "Merge"
Even when not it use and last open. They close up too (along with the whole UI) when the FullScreen.js is activated. Except during the first event upon after program start, only the sub -palette closes.
FS has to be activated again.
Show messages:  1-20  21-35
