Corner Point Selection
All  1-2  3-4
5138.3 In reply to 5138.2
No problem, was hoping maybe I could streamline some editing of imported 2D geometry...was actually thinking if I could select all corner points then invert the selection -- I'd save a few hours of editing (really bad geometry import from the client).
Back to forum lurking mode!!!
Thanks!!!
-AW
5138.4 In reply to 5138.3
Hi AW - depending on what kind of editing you want to do you might be able to get somewhere by using the Rebuild command on those curves:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
That will reconstruct a curve by sampling points along the existing curve and then building a new curve through those sampled points.
Show messages: All  1-2  3-4
