Corner Point Selection
All  1  2-4
5138.2 In reply to 5138.1
Hi AW - right now information about the edit points or even a method to select them are not exposed to script so it's not really possible to make a script that only selects corner points right now, sorry. I will have to add some more stuff into the script interface to make that possible, I've added that to my list of stuff to work on.
5138.3 In reply to 5138.2
No problem, was hoping maybe I could streamline some editing of imported 2D geometry...was actually thinking if I could select all corner points then invert the selection -- I'd save a few hours of editing (really bad geometry import from the client).
Back to forum lurking mode!!!
Thanks!!!
-AW
5138.4 In reply to 5138.3
Hi AW - depending on what kind of editing you want to do you might be able to get somewhere by using the Rebuild command on those curves:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
That will reconstruct a curve by sampling points along the existing curve and then building a new curve through those sampled points.
Show messages: All  1  2-4
