This is a terribly lame subject for my first post here, but is there a script (internal or otherwise) for toggling visibility of points? I know you can hit escape to turn them off, but I can't find a way to turn them on (short of using the button).
Hi Brandroid, put in: ShowPoints
as the command part of the shortcut key and then pressing that key should do the same thing as clicking the Edit > Show pts button.
That will work for both turning on points and also turning off points as well if the selected object already has points turned on.
