New Mac OSX public beta Apr-29-2012 available now
 1-4  5-21
5111.5 In reply to 5111.4
Hi Dinos - that seems to be some kind of bug in the expiration mechanism, possibly only showing up on OS version 10.7.3 - I'm going make an adjustment to how that works and post an updated version shortly.
5111.6 In reply to 5111.4
Hi Dinos, ok I just posted an update (same filename) , which tweaks some of the expiration stuff.
Can you please redownload it and give it a try to see if that problem is fixed now?
5111.7 In reply to 5111.6
Fixed! :-)
Everything else looks ok so far.
Thanks Michael.
Dinos
5111.8 In reply to 5111.7
Great! Glad that's fixed now Dinos, thanks for reporting the problem and testing it.
5111.9 In reply to 5111.8
I'm getting that same mismatch error with 10.6.8, but only on my Imac. It works fine on my macbook pro,
5111.10 In reply to 5111.9
Hi jtucker,
Did you download it a bit earlier today? Try re-downloading it again now, I have put up a new version that should fix that mismatch error now.
Let me know if you still see it with a new freshly downloaded one.
5111.11 In reply to 5111.1
There's also a new bug that's popped up with this release where using a Wacom tablet doesn't work properly, the mouse pointer is offset a ways from the actual click point.
If you see that, you'll need to use a regular mouse for the moment with this particular release.
This is also a new bug that popped up in the support libraries similar to the sporadic startup crash thing.
I'm going to look into rolling back to an older version of the libraries until the fixes for these have trickled down, so I'll probably cook up another release in a couple of days.
5111.12
I like the more unbuged MoI but... the offset command is very slow!
5111.13 In reply to 5111.12
Hi ed,
It seems to be working ok for me over here - is it slow for you on everything that you try like even doing an offset of a line or circle? Or is it slow for you with one particular model? If so can you please post that model so i can check it out?
Also do you mean that the Windows version behaves differently with the particular offset that you're doing? I'd be kind of surprised with that since they're using the exact same code.
5111.14 In reply to 5111.10
yes it is fixed now.
thanks...
5111.15
Hi Michael, long-time-no-see.
I've got my $100 bucks and want to upgrade to V2. I'm testing out some stuff on 64bit Ubuntu 11 these days. Does Moi V2 work there yet?
5111.16 In reply to 5111.15
Hi TwinSnakes - MoI v2 does not run on Linux, but the current MoI v3 beta will run there under Wine just as long as you have a good enough quality OpenGL video driver. Poor quality video drivers are unfortunately quite common on Linux though, so it's hard to know for sure whether it would work ok on your particular system or not.
There's a previous discussion thread about it here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.1
Some people have been successful and some have had problems, it all depends on the robustness of your particular video driver.
5111.17 In reply to 5111.16
great!
thank you!
5111.18 In reply to 5111.11
Michael, I didn't install the new version because I use a Wacom tablet. As soon as the Wacom bug is fixed I'll try it.
5111.19 In reply to 5111.18
Hi Martin, it shouldn't be much longer until a new beta will be out that should fix the Wacom bug, just maybe another day or two.
5111.20
Confirm the Wacom bug, expect the software update, where you can download the old version?
5111.21 In reply to 5111.20
Hi Herbert, the old version is available here:
http://moi3d.com/download/osx/MoI v2.5 beta Jan-31-2012.app.zip
I hope to have a new update ready by the end of the day today.
Show messages:  1-4  5-21
