some help please
 1-10  11-30  31-33
5105.31 In reply to 5105.28
Can you post a sample dwg file to look at?
5105.32 In reply to 5105.28
Hi southpaw,
> yet fully supported the autodesk dwg format(or fbx),
Unfortunately Autodesk basically goes out of their way to make dwg format difficult to deal with... In the future I would like to try to support DXF format though which is actually documented (for 2D drawing entities anyway, not for 3D solids).
Usually though Rhino does a good job with DWG and DXF files, so that's kind of odd that it is not working for you. Like Burr mentioned, can you post some kind of simple example DWG file that is not working for you? That would let us try it with a couple of different programs to see if there would be any other good way for you to transfer stuff.
You might try ViaCAD also. It's really inexpensive at $99 and can be a pretty useful tool in the CAD toolbox:
http://www.punchcad.com/p-9-viacad-2d3d-v8.aspx
5105.33 In reply to 5105.32
Mr. Michael,
I kind of figured that Autocad did that with their default dwg format. I appreciate that you're looking into the dxf format at some point in the future.
Bought the ViaCAD 2D/3D on your suggestion. It imports the older dxfs and dwgs well. Looks like it'll hash up a blueprint pretty quick. Rather 3D model in anything else though, lol. I'll try to like it this summer.
Brian
EDITED: 1 May 2012 by SOUTHPAWAMI
Show messages:  1-10  11-30  31-33
