Testing v3 for vehicle modelling
 1-10  …  71-90  91-110  111-116
5101.111 In reply to 5101.110
Cool beans Michael, if I don't see a click icon/tool then i just assume it's not there, maybe the button should be named as Bend/Flow just to make it clear for people like me :)
Martin
5101.112 In reply to 5101.111
Hi Martin, it's tough to put in long names in the UI, there is only a little bit of space for them. But the actual icon itself does show a straight rectangle being deformed to follow a bent path...
Flow can also be used for some other kinds of deformation purposes like applying a flat pattern onto a curved surface, bending is sort of one piece of it.
5101.113 In reply to 5101.112
Hi Michael - I used flow before starting the car to test MoI on doing vehicle wheels and tyres, just never really noticed the ability to bend things being with in the flow, but it does kind of make sense, like i say - i just jump into the modelling but not the application itself, if the application is intuitive most of the time then i can ride the curve, MoI is like that, and I enjoy it. All the best
Martin
5101.114
Gratulations -The Best Car Modelling in Moi that I have seen.
5101.115
My congratulations Martin!
Your car model is very well done. I'm glad to see that you enjoyed using MoI and you were able to bring your idea to fruition!
Now that you have us all hooked, you're going to have to start producing more works. ;-)
5101.116
This model is now available on GrabCAD @ http://grabcad.com/library/lamborghini-reventon-2008 Feel free to grab, use and render to your hearts content, finish the trim and fillet that's missing on the rear and you'll have a good model, maybe even import the other disc brake I have on here too, and it will be even better. All the best folks
Martin
Show messages:  1-10  …  51-70  71-90  91-110  111-116
