Meshing wish suggestion
All  1-4  5-6
5099.5 In reply to 5099.4
Point taken but I'm not asking for FEA capabilities just the abilyty to select couple isocurves so I the user decide the the poly direction.
similar consept from 3dcoat retopo
5099.6 In reply to 5099.5
Hi adam - actually meshing does already follow the isocurves of the surfaces being meshed.
The way meshing works is by first creating a quad mesh which is in the UV space of the surface - all the edges of those quads are on isocurves of each surface being meshed.
An isocurve has a particular meaning for a NURBS surface - it means a line of constant U or V in the surface's parameter space. Picking a line of some other orientation would no longer be an isocurve, isocurves are only either horizontal or vertical lines in UV space.
Show messages: All  1-4  5-6
