Is it possible to fillet those edges?
 1-8  9-25
5091.9 In reply to 5091.8
Hi Rich_Art, yeah unfortunately that's a particular type of topology and shaping that the filleter has some trouble with.
Another technique that can sometimes help to make things easier on fillets in areas where it has trouble is to put a sort of "hub" where pieces are coming together, see the attached example, that one will fillet up to a radius of 0.2 when it seems to run into some trouble again.
5091.10 In reply to 5091.9
I dont know if I would call that a fillet. More like a constant variable blend!
Here I did your model and used some trimming to allow the blend tool to work.
I also altered the model in a way that allowed the constant fillet to make a result, then did some lower level work to finish it off. Here's a link to that one:
http://youtu.be/7_lVpJqST2A
Both methods though, are left with needing the "n-sided patch" to get a quality surface. Something on my wish list. With that tool, there will be most nothing that MoI could model!
5091.11 In reply to 5091.10
Hi guys,
Both great solutions... To bad Moi can't deal with it without a workaround but both very usable solutions..
Thanks for pointing me in the right direction. :-)
Peace,
Rich_Art. ;-)
A little tut that i made ;) (in French sorry )
Just 4 curves on 2 cube's faces are sufficient for make a complete boolean intersection
Select all / Construct / Boolean Merge
Just kill (or keep and move) the internal volumes!
Print screen of the "Moi work canvas"
EDITED: 21 Apr 2012 by PILOU
5091.13 In reply to 5091.12
Nice nice but you export to?
Did yo made the fillet in Moi??
Peace,
Rich_Art. ;-)
5091.14 In reply to 5091.13
<< Did yo made the fillet in Moi??
Of course yes I have made all that only inside Moi ! ;)
This Export OBJ can works with any prog who accept Ngons: C4D etc...
5091.15 In reply to 5091.14
Yeah I have it now as well. I fillet one edge at the time for the inner part.. Works good now..
See example.. + C4D
Thanks for the help guys.. Moi3D did it again..... yeahhh
Peace,
Rich_Art. ;-)
5091.16 In reply to 5091.15
Cool :)
5091.17
Rich:
>>There is a new tutorial on a C4D forum which shows how to make this<<
can you post the link or need to be logged?
5091.18 In reply to 5091.17
I think you need free registration to see the vids indeed..
The post that is made can be found on,
http://www.c4dcafe.com/ipb/topic/67878-free-video-tutorial-modeling-a-rib-vault-type-ceiling-in-cinema-4d/
Peace,
Rich_Art. ;-)
5091.19 In reply to 5091.18
Here's a quick video of that model, although it IS different than the picture depicted.
5091.20 In reply to 5091.19
Another method :)
I have seen from your example that my second curve was not obliged :)
Except for decoration :)
5091.21 In reply to 5091.20
Hi Frenchy,
Yeah, it's the same thing... I just wanted to put up the visual.
5091.22
Sorry, one more method...
1. sweep circle along edges
2. boolean subtract beaded edges
3. blend all edges
5091.23
with edges removed...
5091.24 In reply to 5091.21
@BurrMan,
Thanks for the vid. I used the same method to fillet those edges.. just one by one works out best..
@beanworks
That is a nice solution as well. Perhaps even better because it is more close to the C4D example in this post,
http://moi3d.com/forum/index.php?webtag=MOI&msg=5091.8
Peace,
Rich_Art. ;-)
5091.25 In reply to 5091.23
Very nice.. Just remake your way and it works great..
Case closed.. :-)Thanks for all the help guy's..... much appreciated.
Peace,
Rich_Art. ;-)
Show messages:  1-8  9-25
