Power SubD-NURBS
 1-5  6-25  26-45  46-64
5088.46 In reply to 5088.45
My son asked if there was a way to take models from SketchUp into MoI... I didn't recommend it.
I like this: (modo power-nurbs site)
“Organic NURBS surfacing is no longer strictly the domain of T-Splines! Modeling in modo and exporting to your CAD package of choice is a powerful workflow. modo+NURBS; two great tastes that taste great together!”
– Branden Coker
Like a "Power-Reeses". ;-) Moi is the chocolate, of course.
This inspires me for a crazy Moi feature idea that is way too implausible to ever exist.
A command that can take two or more surfaces and rebuild them into a new single contiguous one (within reason). That way (Pilou), you could take the SketchUp models and smooth out those "polys".
wait, wait... If you export a multi-surface face NURBS into a poly/Sub-D modeler, apply a little smoothing, then Power-NURBS could work it's magic, and back to MoI. (the wheels turn)
5088.47 In reply to 5088.46
< My son asked if there was a way to take models from SketchUp into MoI... I didn't recommend it.
Sure for an organic model but for other nature of object that can be possible :)
The OBJ export plugin for the free version of Sketchup (OBJ + Material)
By TIG http://forums.sketchucation.com/viewtopic.php?t=33448
5088.48 In reply to 5088.47
Thanks Pilou... this plug-in will be worth experimenting with.
5088.49 In reply to 5088.46
Hi Mike,
It is feasible to have a surface combine tool, but only for the case where 2 surfaces are touching each other along an "untrimmed" edge - meaning having each underlying surface touch each other.
If they touch at some kind of internal trim curve it's not very feasible to combine them together because every NURBS surface is made up of a rectangular grid of control points and it's not very easy to figure out some way to combine together 2 unaligned rectangular grids into one single rectangular grid.
5088.50
Just to chip into this subject, may be a little related, I was just wondering.
Does the geometry library have a kind of fit surface to point cloud?
5088.51 In reply to 5088.50
Hi Danny,
Kind of but it tends to generate wiggly and undulating results, so it's not all that useful as-is.
Also it needs to be given a parameterization, basically an initial starting surface that is then basically deformed to interpolate the given points in the point cloud. The only really easy automatic starting surface is a best fit plane, but that doesn't work very well for point clouds that have some kind of complex 3D shape in them.
You generally can't fit just a single surface to some complex arbitrary point cloud as it may have various complex branches in it, usually such things have to be fit with a sequence of surface patches and not just one surface.
5088.52 In reply to 5088.51
"""""""""""""A command that can take two or more surfaces and rebuild them into a new
> single contiguous one (within reason). """""""""\
Well, thats basically what Power subd nurbs is doing here..... I called them and it can be licensed for something like $25,000 to start......
So, thats like 250 of us putting $100.00 into the kitty... Who's with me boy's!!!!!
lol
5088.53 In reply to 5088.51
Thanks for the point cloud answer......curiosity satisfied, maybe one day.
@ Burr, sounds like a tempting invesment.....or a tax dedutable donation :)
5088.54
New Kid on the Block ;)
www.clayoo.com
EDITED: 25 Jun 2012 by ADAMIO
5088.55 In reply to 5088.54
Hi adamio, is Clayoo generating NURBS data now?
Previously it was only generating mesh data, see discussion of item #3 here:
http://www.clayoo.com/forum/topics/first-thoughts
5088.56 In reply to 5088.48
< plugin Sketchup export OBJ
A little remark : for me it's works only if you save your object .obj inside the folder "Plugins" of Sketchup else nothing append !
EDITED: 25 Jun 2012 by PILOU
5088.57 In reply to 5088.55
Correct is not there yet...
5088.58 In reply to 5088.57
Hi adamio - that's really a key function for it to actually be in the same category as T-Splines or Power SubD-NURBS. But it sounds like it should be coming at some point.
5088.59 In reply to 5088.54
reminds me of TSplines, which I hope AutoDesk does not ruin.
5088.60 In reply to 5088.59
Indeed.
TSplines inside Fusion
I have been testing Fusion on the mac for some time now and to be honnest Autodesk once again failed to impress me.
It even crushes by importing simple DWG files, I can open the same DWG with ViaCad that costs $39 :(
I hope the improve perfomance in the future.
But then again Modo 601 + SubD-NURBS is the biggest fiasco ever.
IMO. If Michael ever considers to bring subs modelling into MoI is gonna be game over for the rest of them.
EDITED: 26 Jun 2012 by ADAMIO
5088.61 In reply to 5088.60
As a modo user i thought the price would be the same as for 3dsmax 295,-USD + a points system, for example.
That would be it ... ;-)
On the other side if sidefx could implement a smoothing function for their SubD to NURBS function in Houdini, so that we don't get facetted output, then i would be also more than happy. Ok, if i would be a student then i would use the free Maya student version.
5088.62 In reply to 5088.61
I downloaded the trail version of obj mesh to solid. http://www.resurf3d.com/Objmesh2solid.htm It does what it purports. It does not like triangles very much. the best way to use it is to make your mesh all quads otherwise if you have to many triangles it hangs. It smooths things out nicely but the problem with it is taking a large file and converting it means you have a large solid file so not an elegant solution.
I have also tried stl to step. http://www.solveering.com/products/products_stl2step.html I didn't think it was that useful but maybe some one else might.
Val
5088.63 In reply to 5088.62
Hi val2,
i downloaded obj mesh to solid too, after reading your post. I tried it with various .obj files from many apps, but managed to get it only to work with the free UVMapper .obj output and modo. Anyways like you said files can get pretty (i mean very) large if you have a larger poly count. As a test i used a mesh preset from modo and it took ages to convert and also ages to load into MoI. Maybe my Mac is to small for such a task, but it seem for small poly objects it's a nice and cheap alternative!
5088.64 In reply to 5088.63
I couldn't get it to work with a blender obj but I could get it to work with 3DSMax. It took forever for me as well. I'm running a I7-2600k with 8gigs so not that powerful but it's not that bad. For small carefully crafted meshes it could be quite useful but other than that I don't think it is up to the job. I think if one did a retopo job on dense meshes it may be OK but that would need some testing.
Show messages:  1-5  6-25  26-45  46-64
