Soild Problem
All  1-2  3-6
No problem !
There were something not clean in these little place! (surely 2 lines in the same place)
I have selected "up face" / copy move / Trim (remove) / Copy Move / Select lines/ Trim (remove)/ Make planar / Extrude
EDITED: 29 Mar 2007 by PILOU
508.4 In reply to 508.3
Thanks a bunch Frenchy!
EDIT
After Frenchy's discovery. I went back and did it from scratch at a higher resolution, and I still wound up with some of my curves overlapping, and points not touching.
I dunno how to address it. But, the workaround is..I joined the curve together starting with small sections of the curve, until I find a section that wont join. Which ends up either being an overlap, or the connecting points being off by a small amount. Once I fix the issue, I continue joining until the curve is closed. With the final test being if the Planar command will create a surface.
Any suggestions on the workflow?
-TS-
EDITED: 29 Mar 2007 by TWINSNAKES
508.5 In reply to 508.4
I have said "maybe" double lines :)
So your problem was the don't touch points or curves overlap
Best for you is redraw your curve with attention because trim / join/ trim etc...
if works can maybe not acceptable if you have forget some little free curves!
508.6 In reply to 508.4
Hi TS,
Well, I think the main thing would be to try and get the pieces created with good alignment in the first place to reduce the amount of messing around later on.
Can you describe some of the steps that you're doing when creating the curves, which are resulting in overlapping or gapped curves?
Is it possible that you have Object Snap turned off (not highlighted in orange in the bottom bar) ?
You should normally be able to stick things together when drawing them, so I'd be interested to know what is going wrong during the creating of the curves. If I knew what was going on there maybe I could figure out something to fix up that process.
Show messages: All  1-2  3-6
