Igis?
5064.1
I've downloaded the trial version of keyshot and I tried various export format from Moi and more specifically "iges" and I noticed that the Moi style names get converted to numbered layer. It's not a big deal but I wonder if it would be possible to preserve the named styles? I also noticed that the named object loose their name with this format but this could be Keyshot way.
Felix
5064.2 In reply to 5064.1
I would mesh my model with MoI.. The MoI mesher will be far superior. So go out with obj to your renderer.
5064.3 In reply to 5064.2
BurrMan,
I agree with you, I tried the obj file format but I forgot that I changed the setup for a mesh only export, it works fine when material is on again. With the obj file I have all the object name and style name.
But all this being fine it's not my point, is there a particular reason that iges files don't have the names I've setup for both objects and styles? Just curious.
Felix
5064.4 In reply to 5064.1
Hi Felix,
> the named styles?
I don't think that there is any mechanism in the IGES file format to have names for layers/styles, that format is structured to just tag things with a "level" which is a numeric id.
There is a mechanism in IGES for specifying object names, and MoI does already make use of it - if you export a named object to IGES and read it back in you should see the names being preserved.
Since IGES has limitations in the file format itself, I'd recommend using a different format for transferring to a rendering program like Keyshot - OBJ format should generally work better for this transfer and the styles list will become a named materials list in the OBJ file and object names are also written to OBJ format. Just in general OBJ format is more focused on rendering data transfer, IGES is focused more on just CAD geometry transfer.
When you export to OBJ from MoI to go into Keyshot, just set the "Output: Quads & Triangles" option in the export dialog, since I don't think that Keyshot likes to deal with complex n-gons.
5064.5 In reply to 5064.3
Hi Felix,
For styles it's because IGES is structured to use numeric id values for what it calls "levels".
For object names, MoI does write those to the IGES file and if they are not going through that means that Keyshot is not reading them.
OBJ format should be more robust for going to a rendering program, it's more widely used for transfer of rendering data.
5064.6 In reply to 5064.5
Michael,
thanks for the explanation. Now that I've turn on material, everything is fine with the obj file format.
Felix
