Solo view?
All  1  2-6
5059.2 In reply to 5059.1
Buttons on the bottom toolbar to select viewport:
5059.3
Oh good Lord.....is it Friday yet? Thanks.
5059.4 In reply to 5059.3
You can make keyboard shortcuts to move to views too.. This is what the "command part" would look like for Top:
script:var vname = 'Top'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) vp.reverseView( vname );
Note the word "Top" in there.
You can set that word to any of the views:
Back
Bottom
Front
Left
Right
Top
For Split view and 3d viewport, the script is:
script:moi.ui.mainWindow.viewpanel.mode = 'Split';
Note the word "Split" in there.
You can set that word to 3D:
5059.5
I found this script to be UBERuseful, which will switch between the viewport under the current mouse cursor location and the quad view.
script:if ( moi.ui.mainWindow.viewpanel.mode != 'split' ) { moi.ui.mainWindow.viewpanel.mode = 'split' } else { var viewport = moi.ui.getViewportUnderMouse(); if ( viewport ) viewport.viewpanel.mode = viewport.name; }
..just put it on the SPACE key or (almost) any other key combination like so:
http://moi3d.com/2.0/docs/moi_command_reference11.htm#shortcutkeys
Cheers,
Marco
EDITED: 11 Apr 2012 by MARCO
5059.6 In reply to 5059.5
Wooo thanks... Never seen this script.. Works great.
Peace,
Rich_Art. ;-)
Show messages: All  1  2-6
