This is curious but probably a known issue. Or, it is me.
All  1-6  7-9
5051.7 In reply to 5051.6
Hi nycL45,
"""""""""""I needed to flatten my wonky curves before booling a domed object"""""""""""
If you go to the front view and select your text, you can grab the "edit frame" and drag it vertically and there will be a "Flat Snap".... Great for flattening out wonky curves....
5051.8 In reply to 5051.6
Hi Leonard, yup I think you've got it - basically the history mechanism is set up so that you could edit the original curve or the surface it is projected on to and see the projection update. It's possible for that update mechanism to get in the way but if it does you can disable it with that Edit > History command.
But like Burr mentions if you want to flatten something it's quicker to go to a side view and use the edit frame - here's a demo video:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3378.4
5051.9 In reply to 5051.8
Edit Frame - I missed that one but will try it out. Checked out the demo video - that's brilliantly painless!
Thanks BurrMan and Michael.
Leonard
Show messages: All  1-6  7-9
