TextAlongCrv ?
 1-17  18-21
5036.18 In reply to 5036.17
Hi TpwUK, if you're going to be producing a rendering as the final output, you don't really need to actually boolean union all the little bits together into a single solid, it's ok for rendering purposes to have them as separate solids that just happen to be sticking through each other.
5036.19
I have gotten up to all kinds of tricks with rendering in order to save computing time and to speed things up Michael, and i still do. This was just to try the stability of version 3 beta, it was stable, but i quit the boolean process after 1hr and 20 mins on a quad core @ 3.2Ghz and 8gb. Any chancr you can tweak the code to be multi-threaded when needed. All the best and thanks for producing a wonderfully intuitive app!
Martin
5036.20 In reply to 5036.19
Hi Martin, I do want to add more multi-threading to MoI in the future but it's a very complex task to manage multiple threads well, and it tends to be easier to implement for things where the stuff that is being calculated is totally separate from each other.
When you are doing a boolean you are often combining things into a single object, and so that aspect involving combination is pretty much the opposite of isolated calculation.
There are probably some aspects that could be calculated in isolation from each other, but just in general it is quite difficult to restructure existing code to be multi-threading friendly, and multithreaded code is notorious for being easy to create all sorts of timing related synchronization bugs, so it has to be approached very carefully, it's not something that you just slap together quickly.
I do want to add it to some particular targeted areas, and in version 2 I did do that for the polygon mesh export, but it's a difficult and time consuming process.
5036.21 In reply to 5036.20
I totally understand and appreciate the complexities of multi-threading, I have several attempts and failures with that and Delphi (Showing my age again) ...
Martin
Show messages:  1-17  18-21
