need help with an "adapter-piece"
All  1-11  12-14
5029.12 In reply to 5029.10
Michael, up early on vacation! Should get sunny today!
Here's a quick video of the 2 different methods.
5029.13 In reply to 5029.10
It takes about 2 seconds to do the blend, and
about 5 to 10 minutes to set up the cylinder and extruded square.
It took me about 2 hours to figure out how to do it...
Finally, reading the MoI documentation on blend,
the key for blend is to use segments of the EDGES of the cylinder and "square",
NOT the circle and rounded square which were used for the creation of the cylinder and rounded square.
Either erase or hide or move or keep them away from the two edges to be blended.
Also, remove the top and bottom of the cylinder and square, so their edges are not selected, or a
bulge blend results.
Select the Edges of the two blue edge segments, one from the cylinder, one from the rounded corner of the square.
Press the blend icon.
Blend or Loft or Sweep then works for the "triangular" area.
EDITED: 19 Feb 2014 by BEMFARMER
5029.14
thank you all very very much! :)
Show messages: All  1-11  12-14
