Script Error
All  1  2-5
5014.2 In reply to 5014.1
Hi Hoinz, are you possibly running some kind of anti-spyware or anti-virus software that might hook into Internet Explorer and modify how it handles scripting on web pages?
MoI v2 uses some of the IE engine for handling its UI so it could be possible that something like that is interfering with MoI's own internal communication as well.
You might try temporarily disabling anything like that which you may be running and see if that solves the problem - if so then there may be some way to set up an exception just for MoI.exe so that it will not interfere with MoI specifically.
In MoI v3 I've moved away from using the IE engine to avoid problems related that type of stuff.
5014.3 In reply to 5014.1
Also it's possible if your system registry gets a bit mangled that IE itself gets confused about how to handle permissions for scripting stuff.
If that's the problem then that can be fixed by doing a reset of IE settings. There's a reset button under the system Control Panel > Internet Options > Advanced tab as shown in this blog post:
http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx
That might fix it up.
5014.4
Hi!
All this don't work. I think it isn't my anti virus program.
I try Moi trail on a second PC with the same anti virus program and it work fine.
I think it is a problem with my main PC:
Win7/64
Prozessor Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz, 3326 MHz, 6 Core
(RAM) 12,0 GB
I try out your tip with resetting IE
I wait on your version 3 cya
5014.5 In reply to 5014.4
Hi Hoinz, yeah I'd recommend doing that IE reset thing - it has cleared up similar things before.
Show messages: All  1  2-5
