Thanks Michael
I went back to my original template, luckily, I had all the solids used to make the fleur saved has separated objects, after playing around with it a bit, I found the micro shelf areas are formed when I boolean Union them together. If I deleted the micro surfaces, it would not join back into a solid, left me with some edges that did not match up, since I was not sure how to fix this, I just cut away the edges and made some patches, then it would reform into a solid. I hope no one will notice a .03mm patch :) I think I will just replace it if the one you created. I'm sure it will cause me less pain, long term :)
P.S, I've just had my first piece cast in Sterling Silver. nothing fancy, but it's something my wife wanted. is there a live post, where users post photos of real world object created from MoI designs?
